| New Reply |
High precision, good accuracy Current Source Schematic |
Share Thread | Thread Tools |
| Feb23-12, 04:04 PM | #18 |
High precision, good accuracy Current Source SchematicMaybe it's not a problem. If you can find a P-MOS with operating gate source voltage of -3V, you still have 2V on Rs to play with. Say if the op-amp output is at 0V for max current, the source will be at +3V, so operating voltage for constant current output at the drain can be from 0 to about +3V. Maybe it's not a problem. |
| Feb23-12, 10:46 PM | #19 |
here's an interesting transistor.. http://www.onsemi.com/pub_link/Collateral/ENN7508-D.PDF see curve Ic versus Vce, pages aren't numbered it's about middle of second page. will those 3 volt opamps drive as much as a milliamp? never mind, just looked at one. http://www.ti.com/lit/ds/symlink/lmv711-n.pdf old jim |
| Feb24-12, 05:40 AM | #20 |
This forum is fantastic, and you're really lovable persons!
So, being inspired by your good advices, I put together the latest project. It uses a low power Differential Amplifier (AD8276B) supplied by a Voltage Reference (ADR3425), a low bias current Op Amp (AD8603) for a feedback loop, then an external current source BJT (T1, to be defined). ![]() Please, have a quick look to that and let me know if makes sense. Later on I will write here my considerations and calculations for the component sizing, based on datasheet and app notes from Analog Devices. Of course, any idea, suggestions or criticisms are welcome! maxim |
| Feb24-12, 10:19 AM | #21 |
About the schematic above, here I have put few comments, hopefully updated by volunteers:
The AD3425 serves as voltage reference to provide a stabilized 2.5V (VREF) The AD8276B is used here as difference amplifier, where VREF is applied to its non inverting input (+) to control the amount of output current, IO. The inverting input (-) is grounded. The output of the AD8267B is used to drive the transistor (T1 to be defined) since a current of a few hundreds of mA is required. The AD8603 op amp is used in the feedback loop of the circuit; it has low bias current (< 1 pA), low offset voltage (< 50 μV), and low temperature drift (< 4.5 μV/°C ) . So, since the AD8276B has RF1/RG1 = RF2/RG2 = 1, the output current Io depends only from the ratio VOUT/R1 = VREF/R1. The accuracy of R1 is critical, so it should have 0.1% tolerance or less. Considering VREF = 2.5V and IO = 100mA, R1 value is 25 Ω. RHALL is ~ 2 Ω Minimal conditions have to be met, fixing Vs = 5V: 1. VHALL = IO × RHALL must be within the AD8603 op amp input range (−0.3 V , 5.2 V) 2. VOUT = IO × (RHALL + R1) must be within the AD8276 SENSE pin voltage range (−10.2 V, 7 V) 3. IO × (RHALL + R1) + 2(−Vs) − 0.2 V to 2(+Vs) − 3 V must be within the AD8276 output voltage range (−7.5 V, 7 V) First 2 conditions are OK. I am puzzled about the last one. |
| Feb24-12, 01:24 PM | #22 |
lets see here
my simple thinking goes thus: AD8276 will hold his inputs equal which dictates that since his inverting input sees Vout/2 and his noninverting sees (2.5+Vhall)/2 equating those yields Vhall = Vout - 2.5 so your circuit will hold 2.5 volts across R1 giving the constant current you seek. Now a sanity check to make sure feedback is proper direction: Assume Rhall drops a teeny bit Vhall accordingly decreases a teeny bit, so (Vout - Vhall) got larger however the decreased voltage at noninverting input lowers pin6 voltage, driving Vout in proper direction to restore balance at inputs. Looks Great so far, said the blind man ! At 100 ma i see Vout = 0.1 * (2 + 25) = 2.7 volts, {corrected - jh} and if hall sensor varied between zero and That amplifier doesn't have a lot of output current capability but datasheet says it can drive to within 0.1 volt of supply with 10 k load so you might get away with a TIP120 darlington driver , 3 Volts + 1.5 for Vbe leaves 0.4 volt headroom. Yungman is way better than me at selecting a transistor. Using a PNP darlington emitter side up and swapping Mr 8276's pins 2&3 would more nearly center his pin 6 voltage at mid-supply. Perhaps with just a tad of emitter resistance for loop stability.... You guys will find a better driver i'm sure, there are even IC's made specifically for boosting opamp drive capability. Your third concern i think is from their warnings to assure headroom, which looks okay from my simplistic approach above. Inputs and Vout are near mid-supply and pin 6 has ~ 1/2 volt headroom even with a darlington's two eb junctions. PNP darligton driver (TIP125?) would give about 1.3 volt .. I have to talk my way through a circuit before attacking its equations. A most elegant looking solution, my friends. old jim |
| Feb25-12, 06:40 PM | #23 |
hope i didnt say something socially wrong - we "Aspies" can do that unwittingly.
fixed my voltage blunder above.. |
| Mar7-12, 01:04 PM | #24 |
Back after a lot of calculations... maybe I am wrong but I've the impression that swapping pins 2 & 3 nothing changes other than the polarity of Vref:
Vout = [V(+IN) – V(-IN)] x gain So if you tie Vref to pin 2 instead of pin 3, Vout will be a negative voltage (assuming negative supply). Going back to the original configuration, now I need help to refine calculations. Let say I want to drive 300mA but keep the same conditions, I would have to increase Vref or R1. If I change Vref to Vref = Io * R1 = 0.3*25 = 7.5V, this is outside the range of AD8276 on a 5V supply. The other option is to change R1. So for example, I could change R1 to 10 Ohms, that means Vref = 1V gives 100mA and 3V gives 300mA, and I think it meets all the input range limitations... Then a TIP120 has a Vbe(on) of 2.5V... Why not use a regular NPN BJT like the 2N1711? It has a Vbe(sat) of 1.3V (max) with IC = 150 mA & IB = 15 mA What do you think about? |
| Mar7-12, 10:01 PM | #25 |
wow, is my face red. i took an old shortcut and it bit me - adding an inverting stage behind an opamp often lets you just swap input pins, and i assumed, without thinking it through, that just swapping 2&3 would do the job.. :Rats. i'm old enough to know better. ![]() I extend my apology. Eternal vigilance ... Soo,, much chagrined - This time i did my algebra. What i missed before is that to swap that internal opamp's input pins , i'd have to swap pins 1&5 in addition to swapping 2&3. That'd leaves us as follows: Pin 2 = +2.5 volts, Vref Pin 3 = 0v Pin 1 = Vhall + Io*R1 Pin 5 = Vhall NOW internal opamp sees at his Inverting input: (Vpin5 + Vpin2)/2 or, Inverting = (Vhall + Vref) /2 and at his Noninverting input: (Vpin1 + Vpin3)/2 or, Non-inverting =(Vhall + Io*R1 +0)/2 Equating those yields (Vhall + Vref) /2 = (Vhall + Io*R1 +0)/2 ; (Vhall + Vref ) = ( Vhall + Io*R1) or, Vref = Io*R1 ;; Io = Vref/R1 which is what we want. Now sanity check for direction of feedback: with a PNP driver and both pairs of those pins swapped IF Io increases by Δi, Non-Inverting input goes up by (Rhall + R1) * Δi but Inverting input goes up by just Rhall * Δi inputs now see difference R1*Δi , with Non-inverting more positive Since Non-inverting input is now greater than Noninverting, AD8276's pin 6 moves positive which moves PNP's base positive, nearer emitter shutting it off, restoring balance. So a PNP could work if you need one. I remember waking up in middle of night thinking i should check on this, but for some reason didn't get it done. You are right. I didnt finish my thinkling and caused you extra work. _____________________________________________________________ Now to your question - Your circuit as you drew it will keep I = Vref/R1 so as you said The internal opamp's inputs need to be kept 1.5V below supply, ie 3.5 volts. So Pin 5 must stay below 7 Volts, okay there. And (pin 1 + pin3)/2 must stay below 7 volts, okay again because Rhall is only 2 ohms and i think you're planning on less than an amp though it. And you can't go negative with just a +5 supply. Note his datasheet says , page 4 "output characteristics", short circiut current limit is 10ma. Graphs of output voltage page 9 figs 19-21 have 1kΩ as lowest load. I dont think he's intended to deliver much current. But with minimum hfe of 100 at 150 ma it should work... But.... Just in case;; The TIP125 datasheet http://www.fairchildsemi.com/ds/TI/TIP125.pdf fig 2 page 3 shows Vce of ~0.75 volt and Vbe of ~1.25 volt when Ic = 250*Ib. That would place Mr AD8276 in the enviable position of sinking very modest current(~ a milliamp) with output voltage well above mid-supply, about 4.25 volts. With the 2N1711 he could have to source 15ma at (Vhall + VRef +Vbe) = 0.2 + 2.5 + 1.3 = 4.0 volts. That leaves only one volt room to +supply. That's right at his limit, see fig 21 of AD8276 datasheet. We should get a cross-check from Yungman on this point. That's my thoughts. Let me know how it looks to you. Thanks for catching my error in previous post. If this one looks cross-threaded anywhere please challenge me on it. You know i'd much rather admit my mistakes than have them cause you aggravation. Thank you , kind sir ! |
| Mar8-12, 08:03 AM | #26 |
Hi Jim,
No worries about possibly error, it's the same for me. Is always a pleasure to talk to nice people like you! So, I would actually use a TIP125 transistor as final stage, it convinces me. Please, help me to fix the polarization network at its best and to choose the proper power supply / Vref for the whole circuit. Your contribution is greatly appreciated. |
| Mar8-12, 09:25 AM | #27 |
Thanks for your kind words.
Well i always seem to have "just one last correction" .. """That would place Mr AD8276 in the enviable position of sinking very modest current(~ a milliamp) with output voltage well above mid-supply, about 4.25 volts.""" SHOULD have read "" That would place Mr AD8276 in the enviable position of sinking very modest current(~ a milliamp) with output voltage -------------------------- Soounds easy enough. You already figured R1. A potentiometer across output of the reference and a voltage follower amp to buffer it would be straightforward approach. AD makes a dual version of AD8603 , the AD8607 so it'd be same package count. How much room do you have for power supply? What physical arrangement do you envision ? Will you make a circuit board or is this a one-of-a-kind hand wired? What range of current adjustment would you like to have? old jim |
| Mar8-12, 10:46 AM | #28 |
![]() -------------------------- You're my friend now ! ![]() All the best, jim! |
| Mar11-12, 09:12 PM | #29 |
Sorry for delay, just dont get to everything anymore.
Beware of that "smartfortress virus" it's out again, turns off your antivirus and tells you you are infected , and blocks most things you can do to get rid of it. Cant even start up in safe mode if it gets far. Microsoft antivirus recognized it yesterday, a couple hours late for me. If you get it google smartfortress and it'll take you to a microsoft link that kills it. I had to run their killer program and then 'restore' to a few days ago because of damage it did. Anyhow --- . Okay - your scheme is so good it doesn't need much change i think. All I did was three things: 1. make Vref variable to give 0-300ma adjustment range with 10 ohm R1. To that end, Added Radj a ten turn pot with locking dial. That lets you set current by a ten turn dial with good resolution. http://search.digikey.com/us/en/prod...02L-ND/1088592 http://search.digikey.com/us/en/prod...US2011_Catlink Added a buffer voltage follower amp A2 to Radj. 500 and 2500 ohm divider on output make his output 0-3 volts for 0-2.5 in. If you use instead ADR3430, omit those resistors. A2 can be another AD8603, or half an AD8607 with other half replacing your 8603 http://www.analog.com/en/all-operati...s/product.html The buffer keeps the resistance of your potentiometer from appearimg in series with Mr8276's internal 40K resistors. 2. Added provision for "Criss-Cross" jumpers at inputs of Mr AD8276. That lets you use either NPN or PNP driver. Install horizontal jumpers for NPN like your 2N1711 or one of Yungman's Mosfets Install diagonal jumpers for PNP like my TIP125. 3. Showed three dots instead of drive transistor. Make two sets of holes on you board, one set for TIP and another for your 2N1711. That way you can use either NPN or PNP or MOSFET driver, emitter up for PNP and emitter down for NPN. http://s232.photobucket.com/albums/e...rMaxim1001.jpg ![]() NOW while typing i realized that you may not need infinite adjustment. If not, consider this: Omit buffer and Radj, go back to 2.5 volt Vref. Make your R1 measuring resistor be three 25 ohm resistors and a switch that lets you select one, or two or three of them in parallel. That'll give you 100, 200 or 300 ma. And in keeping with Detecive Columbo's "One Last Thing";; Yungman's sketch in post 10 had a capacitor to stabilize things. Always a good idea. That additional stage behind Mr8276 increases his open loop gain , but only if we use PNP driver. Sooo we should add a zero ohm resistor (jumper) between top of driver transistor and Vsupply , to be replaced with just a couple ohms to reduce loop gain in case PNP exhibits instability. Can add that to sketch. What's your thoughts so far? |
| Mar11-12, 09:17 PM | #30 |
i see size is a matter. That ten turn pot is big.
BTW while you're experimenting, try that LM317 circuit from post 14 1.25V/.1amp = 12.5 ohms |
| Mar12-12, 10:31 AM | #31 |
![]() http://s232.photobucket.com/albums/e...rMaxim1001.jpg ![]() I will keep you informed about progress. |
| New Reply |
| Tags |
| current, generator, precision, source, stabilized |
| Thread Tools | |
Similar Threads for: High precision, good accuracy Current Source Schematic
| High Current Low Voltage Power Source | Electrical Engineering | 16 | ||
| precision current source | Electrical Engineering | 2 | ||
| Fractional Uncertainty and Precision/Accuracy | Introductory Physics Homework | 0 | ||
| Precision and Accuracy ! | General Physics | 1 | ||
| Accuracy and precision | General Physics | 3 | ||
