What is the radius of the circular hole in the bottom of the water tank?
  • Context: Graduate
  • Thread starter Thread starter mailman85
    Diffeq
The discussion centers on calculating the radius of a circular hole at the bottom of a water tank shaped by revolving the parabola x² = by around the y-axis. The water depth decreases from 4 feet to 1 foot over one hour, leading to the conclusion that the tank will be empty in 1.143 hours. The relationship derived for the depth of water remaining is y(t) = (4 - 3t)², and the parameter b is determined to be 1. The final step involves solving for the area a of the hole using the equation √2a/(πb) = 3.
  • Understanding of calculus, specifically differential equations
  • Knowledge of geometric shapes, particularly parabolas and their revolutions
  • Familiarity with fluid dynamics principles, especially relating to volume flow rates
  • Proficiency in algebraic manipulation and solving equations
  • Study the derivation of volume flow rates in fluid dynamics
  • Learn about the properties of parabolic shapes and their applications in engineering
  • Explore differential equations related to changing volumes and depths
  • Investigate the relationship between area and volume in three-dimensional shapes
Mathematicians, engineers, and students studying fluid dynamics or geometric shapes will benefit from this discussion, particularly those interested in practical applications of calculus and differential equations in real-world scenarios.
mailman85
A water tank has the shape obtained by revolving the parabola x^2=by around the y-axis. The water depth is 4ft at noon when a circular plug at the bottom of the tank is removed. At 1pm the depth of the water is 1ft.
a)find the depth y(t) of water remaining after t hours
b)when will the tank be empty?
c)if the initial radius of the top surface of the water is 2ft, what is the radius of the circuluar hole in the bottom
by using dV/dt=-a(2y)^(1/2) where a is the area of the bottom of the hole of the tank, I solved parts a and b. I found a) y=(8-7t)^(2/3) and b) 1.143 hrs. I am having trouble with part c. Can you help? Thanks.
Since you were able to do parts (a) and (b), I presume that you arrived at the general result that y(t)= (C- ([sqrt](2)a/([pi]b))t)2. Then, since y(0)= 4 and y(1)= 1, that C= 1 and
[sqrt](2)a/([pi]b)= 3 so that y(t)= (4- 3t)2 and the tank will be empty at 1:20 p.m.
Knowing that, at 12:00, when the height of the water was 4 feet, the top had radius 2 ft. Allows you to find b: the tank was formed by rotating the graph of x2= by around the y axis: when x (the radius) is 2, y (the height) is 4: 22= b(4) so b=1.
You also know that [sqrt](2)a/([pi]b)= 3. Since b=1, you can easily solve for a.
12K
19K
