Time it takes for a rocket to reach maximum acceleration
The problem involves a rocket launched vertically with no initial velocity, where propulsion is generated by the ejection of mass at a constant rate. The goal is to determine the time it takes for the rocket to achieve maximum upward acceleration, given that the initial acceleration is zero and a significant portion of the mass is fuel. The context includes concepts from dynamics and rocket propulsion.
  • Participants discuss the need to determine the burn rate of the fuel and question the relationship between fuel consumption and maximum acceleration. Some suggest that maximum acceleration may occur when half the fuel is expended, while others express uncertainty about this assumption.
The discussion is ongoing, with participants exploring different interpretations of the equations provided and the implications of the fuel burn rate. Some guidance has been offered regarding the relationship between thrust, weight, and mass flow rate, but no consensus has been reached on the exact timing of maximum acceleration.
Participants note the importance of knowing the total burn time of the fuel to accurately determine when maximum acceleration occurs. There is also mention of the need to clarify the meaning of certain variables in the equations presented.
becky_marie11
A rocket is launched vertically up with no initial velocity. Propulsion is provided by the ejection of mass with constant velocity of ejection u = 66.0 m/s relative to the rocket and at a constant rate so determined that the initial acceleration is zero. The mass of fuel that can be ejected is 94.0% of the total mass at launch. Assuming constant gravitational acceleration, how long does it take the rocket to achieve maximum upward acceleration?
u=66.0 m/s
Mass of fuel that can be ejected=94.0% of total mass at launch
g=9.81
(1) ΔP=FgΔt
(2) Vf-Vi=uln(Mi/Mf
and maybe...
(3) Ru=Ma
Alright, so first I found the delta t by plugging in the numbers given into (1). Then I solved for the final velocity using (2). Now I have no idea where to go and how to find the maximum acceleration and what time that happens at...just a point in the right direction would be nice!
u=66.0 m/s
g=9.81
(1) ΔP=FgΔt
(2) Vf-Vi=uln(Mi/Mf
and maybe...
(3) Ru=Ma
I think we need to know the burn rate of the fuel - or at least the time it takes for all the fuel to burn, as then we may assume that half the fuel is gone in half that time.
My reasoning is as follows:
Suppose we were able to show that maximum acceleration is reached when half the fuel is gone [i don't believe that is true] then unless we know that the fuel takes a total of 90 seconds to burn, then we wouldn't know that max acceleration was at the 45 second mark.
If the fuel actually lasts 10 minutes, then max acceleration would be at 5 mins.
Perhaps it would be enough to say "when half the fuel is gone".
btw: I do expect that maximum acceleration is nearly 12g, provided the rocket hasn't got too far from the Earth by the time it happens.
The relative mass rate (that is, ejected mass per time divided by initial mass) can be found directly from (3). From this it is a simple matter to find out how long it takes to burn 94% of the mass.
You are clearly reading more into 3 than me, but then I am not aware what Ru is intended to stand for.
I assume OP denotes mass flow rate as R, normally written as [itex]\dot{m}[/itex].
To expand a bit on my earlier post you can from the stated balance of thrust and weight at launch, [itex]\dot{m}u=m_0 g[/itex], and from the relationship between spend mass and time, [itex]m_t = \dot{m}t[/itex], easily find an expression for the spend mass ratio [itex]m_t/m_0[/itex] (the 94%) and solve for time.
  • · Replies 47 ·
  • · Replies 42 ·
  • · Replies 30 ·
