What is the domain of F(x) = √(x^2 - 49)?
  • Context: High School
  • Thread starter Thread starter Learning
    Domain Function
The discussion revolves around finding the domain of the function F(x) = √(x² - 49). Participants explore the conditions under which the function yields real numbers, focusing on the mathematical reasoning behind determining the domain in the context of real numbers.
  • Homework-related
  • One participant seeks help in determining the domain of the function, expressing frustration with previous attempts.
  • Another participant suggests considering when the expression under the square root becomes non-negative.
  • Several participants discuss the implications of negative values under the square root, indicating that these would lead to non-real numbers.
  • A later reply proposes that the domain can be expressed as |x| > 7, explaining that values between -7 and 7 yield imaginary numbers.
  • Another participant clarifies that the domain includes points where the function equals zero, specifically at x = 7 and x = -7.
  • One participant elaborates on the concept of the natural domain of a function, providing examples of how to determine it based on defined values.
  • There is a reiteration that for the function to be defined, the expression x² - 49 must be non-negative, leading to the conclusion about the absolute value condition.
Participants generally agree on the need for the expression under the square root to be non-negative, but there are variations in how the domain is expressed and understood. Some participants propose |x| > 7, while others clarify it as |x| ≥ 7, indicating a lack of consensus on the precise formulation.
The discussion includes various assumptions about the nature of the function and the treatment of real numbers. Some mathematical steps remain unresolved, particularly in the verification of conditions for the domain.
Learning
ok guys, I need some help. I have been working on this problem for half an hour and I am stuck. Every answer I have came up with has been wrong. Here is the problem, find the domain of this function:
F(x)=square root of x^2-49
Thanks for your help.
Mathematics news on Phys.org
On the assumption that you're working with real numbers, work out where f(x) stops being a real number.
like what number could I plug in there?
Think about when √x doesn't exist for a real number x. √4 = 2, √0 = 0, √(-1) = ...?
ok, so the number is a nonreal number when it is a negative. I don't understand what you are trying to say.
OK, you have f(x) = √(x2-49).
Since f is a function from the reals to the reals (assumedly), we need (x2-49) to be non-negative, or f(x) will not be a real number. Specifically, find the range of numbers x where (x2-49) is non-negative.
I somewhat understand that. I'm just really lost with finding domains of a function. My teacher is german with a hardcore accent and he doesn't explain math very well.
I can sympathise with your situation. My Linear Algebra teacher had a thick German accent. Hearing him say such things as "eigenvector" was quite intimidating.
To find the domain, try to find where the function "breaks down". As practise, find the domain of f(x) = 1/(x-1) for x a real number. Think about what value of x would make f(x) make no sense.
I have no idea. I'm totally lost. This is due in less than an hour. Please help me out. Thanks
This may have come too late, but anyway.
The solution is the domain of x is |x| > 7.
Why? Well, we have f(7) = f(-7) = 0. If we set x = 7, and then decrease x slightly, f(x) turns into an imaginary number, and since we're working with reals, this is of no use to us. Similarly for x = -7, if we increase x slightly, we again get an imaginary number. Since (x2-49) is continuous, we know values of f(x) between x = -7 and x = 7 will also give us imaginary numbers. We need x to be greater than 7, or less than -7. We can express this as |x| > 7.
With respect to your teacher, isn't there another one you could ask? It sometimes helps a lot to get more than one explanation for something, particularly if you can't understand the first...
Btw, Lonewolf meant |x| [>=] 7 (the absolute value of x must be equal to or greater than 7), since at x = 7 or x = -7, the function value is [squ]0 = 0.
Another way of saying "|x| [>=] 7" is "x [<=] -7 or 7 [>=] 7"
Btw, I'll try to give an explanation of a function's natural domain. If it is unclear or wrong please point me out.
--- natural domain of a function ---
[note that we are discussing a function that maps a real number to another real number]
The domain of a function can be stated explicitly, such as
f(x) = 1, x >0
The domain of the function above is all real numbers greater than 0. With that restriction, f(0), f(-2), f(-3.43), etc are undefined.
If a function has no domain stated explicitly, then it is understood that the domain consists of all real number x for which f(x) is defined. This implicit domain is called the natural domain of f(x).
Let's look at the function f(x) = 1/x
for x = 1, f(x) = 1/1 = 1 (defined). For x = 5, f(x) = 1/5 (defined also). It turns out that only at x = 0 is f(x) undefined. That is because 1/0 is undefined. So the domain of the function f(x) = 1/x is all x values other than 0.
How about the function f(x)=[squ]x?
At x equal or greater than 0, f(x) is defined. At x less than 0, f(x) is undefined. For example, [squ](-1) is undefined (because there are no real number y that satisfies the property y^2 = -1). That means the natural domain of the function f(x) = [squ]x is all x equal to or greater than 0.
Now, let's go back to your problem. Your function is f(x)=[squ](x^2-49). Let's introduce a new variable b, where b = x^2-49. We can then rewrite your function as f(x) = [squ]b. We already know from the previous explanation that in order to make f(x) defined, b must be equal to or greater than 0. So we write
b [>=] 0
But b = x^2-49, so we can write
x^2-49 [>=] 0
By factoring, we get
(x+7)(x-7) [>=] 0
At x = 7 or x = -7, the value of b = (x+7)(x-7) will be zero (do you know why?). Since [squ]0 is defined, f(x) is defined at these x = 7 and x = -7. At values of x between 7 and -7, the value of b will be less than 0 (verify this). That means f(x) is undefined for -7 < x < 7. For x < -7 or x > 7, b is positive (verify this also) and that means f(x) is defined.
Thus we can conclude that the natural domain of f(x) consists of all x such that
x is equal to -7, or
x is smaller than -7, or
x is equal to 7, or
x is greater than 7
We can write this as |x| [>=] 7.
Does every part of my explanation makes sense to you?
Yes, I did mean that. Thanks.
Any number that you put in for X must result in a number greater than or equal to 0 if you square that number and subtract 49. The numbers that will NOT do this are the numbers that have an absolute value less than 7.
  • · Replies 22 ·
