New Reply
The taste of hot water vs. cold water
Share Thread
Feb23-12, 10:05 PM   #1
In my chemistry class today we learned about equilibrium and how temperature affects the equilibrium constant. An example that was cited was this chemical equation:
H2O <--> H3O+ + OH-
I learned that increasing the heat of the water will drive the equilibrium toward the right side, increasing the concentration of hydronium and hydroxide ions.
I raised my hand in class and asked "is that why hot water tastes bad? you know, because of all the hydronium, perhaps it reacts with the ions in our mouths or something and creates a bad taste in our mouth? maybe?"
I figure it cant be JUST because it's hot. Even water that you've left in your hot car all day tastes like ****, even if you can tolerate the temperature. It's just awful tasting. I know that the ratio of hydronium to hydroxide would remain constant and wouldn't necessarily change the pH of the solution, but its more complicated because of equilibrium yada yada yada, right?
My teacher did not have an answer.
So.... yes? no? maybe?
PhysOrg.com chemistry news on PhysOrg.com
>> Long distance calls by sugar molecules
>> Chemical probe confirms that body makes its own H2S to benefit health
Feb24-12, 12:47 AM   #2
Quote by Coitus View Post
H2O <--> H3O+ + OH-
hello coitus,
This may be not the good answer but i will try to explain your question with what i think a logical answer. Water we drinks is not 100% pure H20; It contains dissolved gases and organic matters. When we are heating the water the dissolved gases escapes and organic matters denatures.This may be the reason why taste of water changes when heating
Feb24-12, 02:42 AM   #3
Admin
To add to what newbe wrote, pH of the water we drink is never exactly 7, because of the dissolved salts (mostly carbonates) present.
Feb24-12, 08:51 AM   #4
Agreed on the dissolved gasses...
FWIW, 'utility-supplied' water may have dissolved chlorine, too. I find our tap water is barely drinkable unless I slosh in 5~~10% of 'sparkling water' to flush the chlorine, replenish the CO2 and lower the pH a bit...
Uh, there was a superb short story by, IIRC, A C Clarke, about Lunar base astronauts who found their water supply gradually tasted too 'wrong' to drink. They could only stomach the recycler's limited output, eventually expired of heat exhaustion and thirst. Flavour turned out to be a surfeit of dissolved oxygen which they could have removed in minutes using an improvised 'boiling stone' and the vacuum outside the base...
Feb25-12, 04:42 AM   #5
Quote by Nik_2213 View Post
Now, THAT's what I call a magnificent story... Thanks for sharing :)
New Reply
Similar discussions for: The taste of hot water vs. cold water
Thread Forum Replies
Why does methyl cellulose dissolve in cold water but not hot water? Chemistry 7
Why does water taste stale after sitting out? Chemistry 17
Water in cold air General Physics 3
Why cold water instead of hot water for rinsing a jacuzzi tub? Chemistry 5
I can taste the plastic I drink water from General Discussion 17
