Measurement of material displacement using recorded material thermal data
The discussion revolves around measuring material displacement through recorded thermal data, specifically focusing on how thermal changes can be correlated with physical displacement in materials when subjected to heating. The scope includes experimental methods and techniques for measuring thermal expansion.
  • Experimental/applied
  • One participant suggests using strain gauges to measure displacement but warns about the potential impact of the gauges on the measurements.
  • Another participant proposes dilatometric measurements as a method for assessing thermal expansion, mentioning the availability of commercial devices for this purpose.
  • A different contribution recommends using a dilatometer with low thermal expansion materials or a calibrated visual system, noting the importance of temperature range and specialized equipment for incandescent specimens.
  • The original poster clarifies their intention to use a thermal camera for measurements and expresses uncertainty about deriving displacement from temperature changes alone. They inquire about the feasibility of calculating thermal expansion and final displacement values using thermal camera data.
Participants present multiple approaches to measuring displacement, including strain gauges, dilatometry, and thermal cameras. There is no consensus on a single method, and the discussion remains open to various techniques and their applicability.
Participants highlight the need for specialized equipment and caution regarding the influence of measurement tools on results. The discussion does not resolve the complexities involved in correlating thermal data with physical displacement.
Researchers and practitioners in materials science, engineering, and experimental physics interested in thermal expansion measurements and related methodologies.
ProgrammerUK
Hello all
I am trying to measure material displacement using measured thermal data.7
While the specimen is heated up, I want to measure how much it changes its length at particular points.
Is this possible?
If you have any further questions or suggestions please do not hesitate to let me know
Thanks in advance
Programmer UK
Sounds like you want to attach strain gages to the specimen. Be careful that the gages themselves don't affect the measurement - it can be very tricky to account for this.
Alternatively, you could perform a dilatometric measurement. There are commercial devices allowing for the measurement of thermal expansion.
Lastly, IR cameras might be useful if the resolution is sufficient for your needs.
Either use a dilatometer (with very low thermal expansion, e.g., ceramic) or calibrated visual system or both. It really depends on the temperature range.
One needs special eqipment for specimens that are incandescent.
Laser based dilatometers and micrometers maybe used.
Thanks for the replies.
I am actaully trying to measure it using a thermal camera, but I will get the change in temperature from this not the change in displacement.
I was also thinking of performing a dilatometric measurement but I thought I would get this information using a thermal camera only.
Is there a way I can get the thermal expansion from the material using the thermal camera and calculating the final displacement value?
Thanks in advace
Programmer UK
  • · Replies 26 ·
  • · Replies 16 ·
15K
