Perfectly inelastic, rigid collision, vel. ever 0?
  • Context: Graduate
  • Thread starter Thread starter wvguy8258
    Collision Inelastic
The discussion revolves around the conceptual implications of a perfectly inelastic collision between a rigid ball and an immovable wall. Participants explore the nature of velocity during such a collision, particularly the moment when the ball's velocity transitions from positive to negative, and whether it can be zero at any point during the process.
  • One participant questions the physical plausibility of a perfectly rigid wall and ball, suggesting that such a scenario may represent a contradiction or impossibility.
  • Another participant argues that during the collision, the velocity of the ball does not need to be continuous and may not be defined at the moment of impact, possibly relating to concepts like Dirac's delta.
  • A participant proposes that the position versus time graph for the ball would have a peak at the wall's location, indicating that the instantaneous velocity derivative is not defined at that point.
  • One participant suggests that the concept of rigid bodies is non-existent and recommends considering 'nearly' rigid objects to avoid infinities in the discussion.
  • Another participant briefly mentions the need to reconsider the type of collision, suggesting it might be elastic rather than inelastic.
Participants express differing views on the nature of the collision and the implications of rigid bodies, with no consensus reached on the physical validity of the scenario or the behavior of velocity during the collision.
The discussion includes assumptions about the rigidity of bodies and the nature of inelastic collisions, which may not hold in practical scenarios. The implications of infinite acceleration and instantaneous changes in velocity are also noted as problematic.
wvguy8258
This likely represents a physical impossibility or contradiction, but I'd like to know that or, if not, understand what is going on at a deeper level.
Let's say we have a perfectly rigid and immovable wall. We have a perfectly rigid (doesn't compress) ball moving toward it at 10 m/s. The two meet and the collision is perfectly inelastic and so the ball moves off in the opposite direction afterward. I would assume it would reach 10 m/s given I believe an inelastic collision involves no loss.
Now, since the ball changed directions, it makes sense that the ball at some instantaneous point in time had a velocity of 0. However, since both objects in the system are incompressible, it is hard for me to imagine the ball not doing the following:
1. losing all velocity in the original direction instantaneously (so I suppose infinite negative acceleration)
2. at the same moment begin moving in the opposite direction
I know that if the velocity changes sign it must at some point be zero, however I can't picture it like a series of still shots where I can intuitively get a grasp of that ball being still at all. It is obviously easier to do this with usual collisions (tennis ball meets wall).
I'm thinking my problem is: 1. no experience with this type of system as it doesn't exist and so my intuition can't handle it and 2. I believe the moment at which velocity is exactly zero would be infinitely short and my mind doesn't deal with infinitely small time quantities well.
Any help? Thanks, if I'm asking an old question, let me know. Didn't find it on a search here.
Seth
My thoughts:
Fine.
No. The velocity function needs not to be continuous. The velocity of the ball when it hits the wall isn't defined (with your assumptions above), maybe it has to see with Dirac's delta; I am not 100% sure here, but it's definitely not 0 m/s.
fluidistic said:
My thoughts:
Fine.
Thank you. So, I'm not totally crazy ;)
So, a position versus time graph (position is in one dimension) for the ball would be linear but with a peak at the wall's location. Therefore, if we take the 1st derivative of the function to find instantaneous velocity, this derivative is not defined at the abrupt peak (a witches hat shape). Is my interpretation correct? This is very fascinating to me, thank you. -Seth
I think so.
:smile:
wvguy8258 said:
This [strike] likely [/strike] represents a physical impossibility or contradiction
Scratch the word 'likely'. Rigid bodies are non existent. It's like asking what happens when I travel at the speed of light. Both are physically impossible. You might want to assume, instead, that the objects are 'nearly' rigid, and that the collision is 'nearly' totally elastic. Gotta get rid of those infinities.:-p
Just a thought experiment.
elastic, not inelastic
  • · Replies 24 ·
  • · Replies 25 ·
13K
  • · Replies 49 ·
