Register to reply
Show that a transformation is canonical
by fluidistic
Tags: canonical, transformation
Share this thread:
fluidistic
#1
Feb29-12, 04:13 PM
PF Gold
fluidistic's Avatar
P: 3,207
Show that the following transformation is canonical:
[itex]Q=\ln \left ( \frac{\sin p }{q} \right )[/itex], [itex]P=q \cot p[/itex].
2. Relevant equations
A transformation is canonical if [itex]\dot Q=\frac{\partial H'}{\partial P}[/itex] and [itex]\dot P =-\frac{\partial H'}{\partial Q}[/itex].
H' is the Hamiltonian in function of Q and P.
3. The attempt at a solution
I've calculated [itex]\dot Q = \dot p \cot p - \frac{\dot q \sin p }{q}[/itex] and [itex]\dot P=\dot q \cot p - \frac{q \dot p}{\sin ^2 p}[/itex].
Now I guess I must check out if the conditions about the partial derivatives of the Hamiltonian are satisfied but I do not know either H(q,p) nor do I know H'(Q,P). I'm stuck here.
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
fluidistic
#2
Mar2-12, 03:57 PM
PF Gold
fluidistic's Avatar
P: 3,207
Ok guys, discard my attempt in my last post.
I've found in some class notes and in Landau&Lifgarbagez's book the necessary condition for a transformation to be canonical. If I'm not wrong, I must show that
I)[itex][Q,P]_{q,p}=1[/itex]
II)[itex][Q,Q]_{q,p}=0[/itex]
III)[itex][P,P]_{q,p}=0[/itex].
Where [itex][f,g]_{p,q}[/itex] denotes the Poisson brackets of f and g with respect to p and q. In other words, this is worth [itex]\frac{\partial f}{\partial p} \frac{\partial g}{\partial q}-\frac{\partial f}{\partial q} \frac{\partial g}{\partial p}[/itex].
Now I have that [itex]Q=\ln \left ( \frac{\sin p }{q} \right )[/itex] and [itex]P=q \cot p[/itex].
I tried to be careful in doing the partial derivatives. I found out that:
(1)[itex]\frac{\partial Q}{\partial p}=q \cot p[/itex]
(2)[itex]\frac{\partial P}{\partial q}= \cot p[/itex]
(3)[itex]\frac{\partial Q}{\partial q}=-\frac{1}{q}[/itex]
(4)[itex]\frac{\partial P}{\partial p}=q(-1- \cot ^2 p)[/itex]
Using this, I found out I) to be worth [itex](1-q) \cot ^2 p-1[/itex]. Unfortunately this isn't worth 1. What am I doing wrong?
Edit: I just found a mistake in my definition of Poisson's brackets. But now I find I) to be worth [itex]1+ \cot ^2 p-q \cot ^2 p[/itex] which is still wrong. I've rechecked the partial derivatives, I do not see any mistake, yet my result keeps being wrong.
Edit 2: This can be rewritten as [itex]\frac{1}{\sin ^2 p}-q \cot ^2 p[/itex]. This is not worth 1 so that the transformation isn't canonical, which is absurd. I do not see any mistake.
Edit 3 : I am nut guys! I found out the mistake in a derivative. I now reach all the results I should, problem solved!
Register to reply
Related Discussions
Canonical Transformation Advanced Physics Homework 7
Canonical Transformation Classical Physics 0
Canonical Transformation Advanced Physics Homework 1
Canonical transformation Advanced Physics Homework 2
Canonical transformation Introductory Physics Homework 1
