Dirac delta and fourier transform
The Dirac delta function, represented as δ(t - u), is fundamentally linked to the Fourier transform, specifically as a Fourier transform pair with the complex exponential exp(-iuω). The relationship indicates that a complex exponential with frequency u has all its energy concentrated at that frequency. The equation δ(t - u) = (1/2π)∫ exp(iω(t-u)) dω is noted as mathematically nonrigorous, but the correct interpretations involve the Fourier transform operator, where F(δ(t-u)) = exp(-iωu) and δ(t-u) = F^(-1)(exp(-iωu)), understood in the context of distributions.
  • Understanding of Fourier transforms and their properties
  • Familiarity with the Dirac delta function and its applications
  • Knowledge of distribution theory in mathematics
  • Basic concepts of complex analysis, particularly complex exponentials
  • Study the properties of the Dirac delta function in signal processing
  • Learn about the implications of the Fourier inversion theorem
  • Explore distribution theory and its applications in mathematical analysis
  • Investigate the relationship between discrete Fourier series and continuous Fourier transforms
Mathematicians, physicists, and engineers who work with signal processing, distribution theory, or Fourier analysis will benefit from this discussion.
aaaa202
In my book the dirac delta is described by the equation on the attached picture. This realtion is derived from the Fourier transform, but I'm not sure that I understand what it says. If u=t it is clear that one gets f(u) in the Fourier inversion theorem. But why wouldn't u=t? In the derivation of the Fourier transform from the discrete Fourier series t was just changed to u in the expression of the coefficients to avoid confusion.
Can anyone try to picture what this expression fundamentally says? I should suspect that it is like the analogue of the ortogonality relation of the discrete Fourier series, but I can't quite understand it.
And what would the situation u≠t represent?
What it is saying is that
[tex]\delta(t - u)[/tex]
and
[tex]\exp(-iu\omega)[/tex]
are a Fourier transform pair. A complex exponential with "frequency" equal to [itex]u[/itex] has a Fourier transform with all of its energy concentrated at [itex]u[/itex].
P.S. The equation
[tex]\delta(t - u) = \frac{1}{2\pi}\int_{-\infty}^{\infty} \exp(i \omega(t-u) d\omega[/tex]
is mathematically nonrigorous. The integral on the right hand side does not actually exist for any values of [itex]u[/itex] and [itex]t[/itex]. What is true is that if [itex]\mathcal{F}[/itex] denotes the Fourier transform operator, then
[tex]\mathcal{F}(\delta(t-u)) = \exp(-i\omega u)[/tex]
and
[tex]\delta(t-u) = \mathcal{F}^{-1}(\exp(-i\omega u))[/tex]
in the sense of distributions. See here for more details:
http://en.wikipedia.org/wiki/Distribution_(mathematics)
  • · Replies 31 ·
