| New Reply |
Change of angle of aberration of light / change of velocity |
Share Thread |
| Mar1-12, 02:08 PM | #1 |
Change of angle of aberration of light / change of velocityCode:
cos (y+b) = ((cos (y) - x)/(1 - x cos(y))) x=v/c y=angle of the source b=angular change -x=1.00 -x=0.80 -x=0.60 -x=0.40 -x=0.20 x=0.00 x=0.20 x=0.40 x=0.60 x=0.80 x=1.00 y=0.00 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 y=0.63 -0.6283 -0.4125 -0.3062 -0.2091 -0.1097 0.0000 0.1291 0.2931 0.5242 0.9169 2.5133 y=1.26 -1.2566 -0.7814 -0.5597 -0.3687 -0.1858 0.0000 0.1977 0.4182 0.6794 1.0247 1.8850 y=1.88 -1.8850 -1.0247 -0.6794 -0.4182 -0.1977 0.0000 0.1858 0.3687 0.5597 0.7814 1.2566 y=2.51 -2.5133 -0.9169 -0.5242 -0.2931 -0.1291 0.0000 0.1097 0.2091 0.3062 0.4125 0.6283 y=3.14 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 y=3.77 -3.7699 -2.1736 -1.7808 -1.5497 -1.3858 -1.2566 -1.1470 -1.0475 -0.9504 -0.8441 -0.6283 y=4.40 -4.3982 -3.5379 -3.1927 -2.9314 -2.7110 -2.5133 -2.3275 -2.1446 -1.9535 -1.7318 -1.2566 y=5.03 -5.0265 -4.5513 -4.3297 -4.1386 -3.9557 -3.7699 -3.5722 -3.3517 -3.0905 -2.7452 -1.8850 y=5.65 -5.6549 -5.4391 -5.3328 -5.2357 -5.1362 -5.0265 -4.8974 -4.7335 -4.5023 -4.1096 -2.5133 y=6.28 -6.2832 -6.2832 -6.2832 -6.2832 -6.2832 -6.2832 -6.2832 -6.2832 -6.2832 -6.2832 -6.2832 change in angle per additional 0.1 increase of v/c -x=1.00 -x=0.80 -x=0.60 -x=0.40 -x=0.20 x=0.00 x=0.20 x=0.40 x=0.60 x=0.80 x=1.00 y=0.00 N/A 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 y=0.63 N/A 0.2158 0.1063 0.0971 0.0995 0.1097 0.1291 0.1639 0.2311 0.3927 1.5964 y=1.26 N/A 0.4752 0.2217 0.1910 0.1829 0.1858 0.1977 0.2205 0.2613 0.3452 0.8603 y=1.88 N/A 0.8603 0.3452 0.2613 0.2205 0.1977 0.1858 0.1829 0.1910 0.2217 0.4752 y=2.51 N/A 1.5964 0.3927 0.2311 0.1639 0.1291 0.1097 0.0995 0.0971 0.1063 0.2158 y=3.14 N/A 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 y=3.77 N/A 1.5964 0.3927 0.2311 0.1639 0.1291 0.1097 0.0995 0.0971 0.1063 0.2158 y=4.40 N/A 0.8603 0.3452 0.2613 0.2205 0.1977 0.1858 0.1829 0.1910 0.2217 0.4752 y=5.03 N/A 0.4752 0.2217 0.1910 0.1829 0.1858 0.1977 0.2205 0.2613 0.3452 0.8603 y=5.65 N/A 0.2158 0.1063 0.0971 0.0995 0.1097 0.1291 0.1639 0.2311 0.3927 1.5964 y=6.28 N/A 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 When using relativistically corrected velocities, we get: -x=0.76 -x=0.66 -x=0.54 -x=0.38 -x=0.20 x=0.00 x=0.20 x=0.38 x=0.54 x=0.66 x=0.76 y=0.00 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 y=0.63 -0.3904 -0.3384 -0.2754 -0.1994 -0.1083 0.0000 0.1273 0.2744 0.4408 0.6238 0.8186 y=1.26 -0.7343 -0.6255 -0.4978 -0.3502 -0.1834 0.0000 0.1950 0.3946 0.5911 0.7772 0.9475 y=1.88 -0.9475 -0.7772 -0.5911 -0.3946 -0.1950 0.0000 0.1834 0.3502 0.4978 0.6255 0.7343 y=2.51 -0.8186 -0.6238 -0.4408 -0.2744 -0.1273 0.0000 0.1083 0.1994 0.2754 0.3384 0.3904 y=3.14 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 y=3.77 -2.0753 -1.8805 -1.6974 -1.5310 -1.3839 -1.2566 -1.1483 -1.0572 -0.9812 -0.9183 -0.8663 y=4.40 -3.4608 -3.2905 -3.1044 -2.9079 -2.7083 -2.5133 -2.3299 -2.1631 -2.0155 -1.8877 -1.7790 y=5.03 -4.5042 -4.3955 -4.2677 -4.1201 -3.9533 -3.7699 -3.5749 -3.3753 -3.1788 -2.9927 -2.8224 y=5.65 -5.4169 -5.3649 -5.3019 -5.2260 -5.1349 -5.0265 -4.8993 -4.7522 -4.5858 -4.4027 -4.2079 y=6.28 -6.2832 -6.2832 -6.2832 -6.2832 -6.2832 -6.2832 -6.2832 -6.2832 -6.2832 -6.2832 -6.2832 change in angle per additional 0.1 increase of rapidity -x=0.76 -x=0.66 -x=0.54 -x=0.38 -x=0.20 x=0.00 x=0.20 x=0.38 x=0.54 x=0.66 x=0.76 y=0.00 N/A 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 y=0.63 N/A 0.0520 0.0630 0.0760 0.0911 0.1083 0.1273 0.1471 0.1664 0.1831 0.1948 y=1.26 N/A 0.1087 0.1277 0.1476 0.1668 0.1834 0.1950 0.1996 0.1965 0.1861 0.1703 y=1.88 N/A 0.1703 0.1861 0.1965 0.1996 0.1950 0.1834 0.1668 0.1476 0.1277 0.1087 y=2.51 N/A 0.1948 0.1831 0.1664 0.1471 0.1273 0.1083 0.0911 0.0760 0.0630 0.0520 y=3.14 N/A 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 y=3.77 N/A 0.1948 0.1831 0.1664 0.1471 0.1273 0.1083 0.0911 0.0760 0.0630 0.0520 y=4.40 N/A 0.1703 0.1861 0.1965 0.1996 0.1950 0.1834 0.1668 0.1476 0.1277 0.1087 y=5.03 N/A 0.1087 0.1277 0.1476 0.1668 0.1834 0.1950 0.1996 0.1965 0.1861 0.1703 y=5.65 N/A 0.0520 0.0630 0.0760 0.0911 0.1083 0.1273 0.1471 0.1664 0.1831 0.1948 y=6.28 N/A 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 r=rapidity Solution for b': http://www.quickmath.com/webMathemat...29-y&v2=r&v6=1 Solution for b'': http://www.quickmath.com/webMathemat...2%29&v2=r&v6=1 Solution for b''=0: http://www.quickmath.com/webMathemat...v11=0&v12=2*pi Rapidity (Horizontal) vs. Theta_s (Vertical) (for the condition that b'' with respect to r eq 0).png See the larger context of the plot at http://www.quickmath.com/webMathemat...v11=-20&v12=20 Observing the second derivative of the aberration angle with respect to changes in rapidity r, represented above as b'' (=[itex]\left(\theta_o-\theta_s\right)''[/itex]), does not require knowledge of the "true" b, and nor does it require that one choose a specific frame of reference to determine the initial value of r, as changes in r are invariant with respect to inertial frames. For constant force, the derivative of r with respect to time is a constant. Thus, a constant value of b', where b''=0, would be observed by taking a sample of b at equally-spaced time intervals and noting the minimal change in slope that results from plotting b over that slope. Observing a condition where b''=0 also does not require knowing the value of y ([itex]\theta_s[/itex]). However, if one can find [itex]\theta_s[/itex] and r, one can also find b. There are upper and lower bounds for r for which there are no real solutions. A test device can therefore be sent to determine an interval of r in which solutions exist. The length of the interval of r containing the real solutions does not depend on the frame of reference of an external observer. It is well defined by the above solution (http://www.physicsforums.com/attachm...1&d=1330650117). To go from one extreme solution to another requires specific changes of [itex]\theta_s[/itex]. In this way, [itex]\theta_s[/itex] can be known simply by alternating between: 1) observing the rate change of observed b' under constant linear acceleration, and 2) changing direction. From there, r can be known. Thus, v/c can also be known. The value of b can thus be known. Therefore, b is totally independent of the frame of reference. In this sense, this value of b is a "real" aberration angle. v/c in turn is a definitive velocity with a direction of an angle [itex]\theta_s[/itex] away from the light path. Thus, this definitive velocity between the light and the interceptor of that light is a kind that is independent of a distant observer, and thus, it is also independent of the frame of reference. A specific set of frames of reference would observe an orthogonal velocity between the light and the interceptor matching that of this definitive orthogonal velocity. This would indeed be a special set of inertial reference frames. If we were to repeat this example with variations in x and y, each having their own corresponding special sets of inertial reference frames, it would stand to reason that a single inertial reference frame would be a member of all of these sets. The above suggests that rapidity provides a mathematical loophole in relativity in which a preferred frame could actually be found in principle. However, there are unknowns that will always be unknown (or relative to the observer) if, on the contrary, neither the angles nor the orthogonal velocity were definitive: Caption: "Comoving Star and Planet" "Observer 1 sees…." "Observer 2 sees…." "How do we know which is the actual path?" "Can we “really” know the angle between the light path and the object’s velocity?" Answer to question #1 would be, "We don't." Answer to question #2 would be, "We can't." |
| New Reply |
Similar discussions for: Change of angle of aberration of light / change of velocity
| change in angle gives change in one side of triangle | Calculus | 0 | ||
| change in velocity of light with change in optical density | Classical Physics | 1 | ||
| Calculating Turn Radius Change During Bank Angle Change | General Physics | 1 | ||
| light velocity change in different medium | General Physics | 4 | ||
| Is the magnetic field change linear with the velocity change of a particle? | General Physics | 1 | ||
