| New Reply |
Linear Algebra, Orthonormal question |
Share Thread | Thread Tools |
| Mar1-12, 02:50 PM | #1 |
I have this question that I am trying to figure out about orthonormality,I have tried to take a picture of it and put it on here but I can't figure out the url. Anyway I will try and write it out. Show that the vector {sin(x),cos(x)} is a basis for the vector space defined by: V={asin(x) + bcos(x) l a,b ε ℝ, 0≤ x ≤ pi} using the inner product : <f,g>=∫(0 to pi)fgdx, fgεV and determine an orthonormal basis. 2. Relevant equations 3. The attempt at a solution I found the integral of sin(x)cos(x)dx between 0 and pi to be 0. This make it orthonormal right as it's the same as the dot product. Now I think I have to find out whether <f,f> is = 1 (of unit length) so I did integral of sin^2(x)dx between 0 and pi but found pi/2. I also found the same for cos^2(x). Does this mean they are not orthonormal? I don't know if it makes a difference that <f,f>=<g,g>. Thanks |
| Mar1-12, 03:06 PM | #2 |
| Mar1-12, 03:09 PM | #3 |
P.S. It's clear that V is spanned by sin(x) and cos(x), but the definition of a basis also requires that these functions must be linearly independent. Did you show that?
| Mar1-12, 03:13 PM | #4 |
What I find helps when you're first working with the notion of 'functions as vectors' is to look back to your basic 3-vectors and think about what these properties mean for them.
Orthogonal 3-vectors have a.b = 0, orthogonal functions have f.g = 0 Normalised vectors have a.a = 1, normalised functions have f.f = 1 Think about how you normalise 3-vectors. Think about how you orthogonalise 3-vectors. Here's another little problem you can do which is kinda fun, build up a set of orthogonal polynomials using the gram-schmidt process (these polynomials are the legendre polynomials) |
| Mar1-12, 03:20 PM | #5 |
| Mar1-12, 03:23 PM | #6 |
I however don't know how to express this in proper notation. |
| Mar1-12, 04:36 PM | #7 |
| Mar1-12, 04:37 PM | #8 |
| Mar1-12, 04:40 PM | #9 |
a cos(x) + b sin(x) = 0 for all x, then a and b must be 0. So pick some specific values of x that are easy to work with. I suggest x = 0 and x = pi/2. |
| Mar1-12, 04:41 PM | #10 |
Isn't it [tex]\int_{0}^{\pi} sin^2(x) dx[/tex]? This should work out to pi/2, not pi. And similarly for cos(x). |
| Mar1-12, 04:45 PM | #11 |
Yeh originally I did it from 0 to pi but when I double checked for some reason I made a mistake and did it from -pi to pi. Ok so I just need (pi/2)^(-1)? |
| Mar1-12, 05:15 PM | #12 |
acos(0)+bsin(0)=0 Then a must be 0. acos(pi/2)+bsin(pi/2)=0 then b must be 0. Is it enough to write this, or is there some sort of other form I can generalize it for? |
| Mar1-12, 07:00 PM | #13 |
| Mar1-12, 07:04 PM | #14 |
| Mar1-12, 07:47 PM | #15 |
I understand all of it, and have managed to complete 2 similar questions now. My only question is, why is it the square root? Surely if <f,f> = pi/2 then we need 2/pi to make this 1? |
| Mar2-12, 12:05 AM | #16 |
[tex]<h,h> = <\alpha f, \alpha f> = \alpha^2 <f,f>[/tex] You want this equal to 1, so [tex]\alpha^2 = 1/<f,f>[/tex] and hence [tex]\alpha = \sqrt{1/<f,f>}[/tex] |
| Mar2-12, 03:37 AM | #17 |
Yeh I was thinking just at the end not the fact that they are going to multiply each other. Thanks for all your help Jbunnii
| New Reply |
| Tags |
| algebra, linear, orthogonal, orthonormal, vector |
| Thread Tools | |
Similar Threads for: Linear Algebra, Orthonormal question
| Algebra : Finding orthonormal basis for the intersection of the subspaces U and V | Calculus & Beyond Homework | 7 | ||
| Linear Algebra: Orthonormal Basis | Calculus & Beyond Homework | 5 | ||
| Linear transformation of an orthonormal basis | Calculus & Beyond Homework | 1 | ||
| Linear independence of orthogonal and orthonormal sets? | Linear & Abstract Algebra | 8 | ||
| [SOLVED] linear algebra - inner product and linear transformation question | Calculus & Beyond Homework | 0 | ||
