New Reply
Standard conditions vs. Standard state
Share Thread Thread Tools
Mar2-12, 09:30 PM   #1
What's the difference between standard conditions and standard state? I noticed in my thermodynamics chapter that in standard state, the reaction quotient is 1 because all activities are equal to 1 (if I remember correctly).
Standard conditions is about standard temperature and pressure right?
Well is there any relation between the two terms? Anything that has to do with thermodynamics?
Thanks!
BiP
PhysOrg.com
PhysOrg
chemistry news on PhysOrg.com
>> Detecting mirror molecules: New technique reliably tells left-handed from right-handed variant of a compound
>> Chemists devise inexpensive, accurate way to detect prostate cancer
>> Overcoming resistance to anti-cancer drugs by targeting cell 'powerhouses'
Mar3-12, 08:02 AM   #2
I think there was a related discussion about this topic a while back, but anyway....
Standard Temperature and Pressure (STP) is considered to be 0°C and 1 bar. Because of the fact that STP requires a refrigerator to exist, many people will mention Standard Ambient Temperature and Pressure (SATP), which is 25°C and 1 bar. This should be, hopefully, the conditions at your typical lab bench. :)
A standard state is different. It's a set of conditions which allows for fairly easy comparisons of thermodynamic properties (and calculations thereof). While the standard state quantities one sees in textbooks for secondary level and introductory university level chemistry are for STP and/or SATP, they're not the only ones by any means. For example, if one gets into geochemistry, you're going to need standard state values at pressures nowhere near those values for doing your work. There's also an idealization of either gas or solution behavior (e.g., ideal gas behavior or infinite dilution limit).
New Reply
Thread Tools
Similar Threads for: Standard conditions vs. Standard state
Thread Forum Replies
Can you make a solution under standard conditions? Chemistry 3
Find standard matrix of linear transformation satisfying conditions Calculus & Beyond Homework 1
Enthalpy change with standard conditions Chemistry 32
Changing standard error to standard deviation. Set Theory, Logic, Probability, Statistics 1
Quadratic, standard and standard form of a curve Calculus 9
