Spining Sphere magnet inside rim of coils how do u calculate voltage
The discussion centers on calculating the voltage produced by a spinning Neodymium magnet within a coil setup. The scenario involves a one-inch diameter magnet levitated in a vacuum, surrounded by eight coils made of copper wire. Key factors influencing the voltage output include the number of turns in the coils, the gauge of the wire, the strength of the magnet, and its rotational speed in revolutions per second. It is established that an external power source is necessary to maintain the magnet's spin when a load is connected.
  • Understanding of electromagnetic induction principles
  • Familiarity with coil configurations and their effects on voltage
  • Knowledge of Neodymium magnet specifications and properties
  • Basic concepts of resistance and external power sources in electrical circuits
  • Research the formula for calculating induced voltage in coils (Faraday's Law of Electromagnetic Induction)
  • Explore the effects of coil turns and wire gauge on voltage output
  • Study the characteristics of Neodymium magnets and their magnetic field strength
  • Investigate methods for maintaining rotational motion in magnetic systems
Physics enthusiasts, electrical engineers, hobbyists interested in electromagnetic systems, and anyone exploring theoretical applications of magnetism and voltage generation.
Comandant Lasard
Can we please imagine that a sphere Neodymiun magnet with a diameter of one inch was suspended or leviated, reducing friction to none, then we put this magnet inside an acrylic tube that created a vacuum by pumping out all the air out allowing the sphere to spin at enormous velocity with very minimal effort. Also bare with me and imagine 8 coil setup around this spining magnet, forming a circle or octogan around this, the coils surround can be of any basic magnetic or copper wire of your choosing and the loops it created would be made to creat a certain voltage. What would be the formula to figure out, depending on the numbers of turns and gauge of wire of the coils, the voltage produced? This would depend on the sizE and strength of the magnetic its speed (revolutions per second) the number of turns of the coil and length of wire. Can some one give me a place to start. I am not a engineer but i am very interested in some of your ideas. The coil and length of the wire and type can be inserted by you if you don't mind. Please return or comment. This is just a imaginary case, so please do not try and attack because of leviation, this a purely theoretical case.
The output voltage depends on some parameters.
However, if you connect any load (resistance) to the terminals, the magnet will stop.
So, you will need some external power source to keep the magnet spinning.
  • · Replies 16 ·
12K
9K
  • · Replies 27 ·
