A block is pulled with constant tension up an incline, find the distance?
by clesling
Tags: block incline, distance, intro physics, physics, tension
clesling
clesling is offline
#1
Mar6-12, 12:56 PM
P: 4
A mass m = 13kg is pulled along a horizontal floor with no friction for a distance of d = 5.1m. Then the mass is pulled up an incline that makes an angle theta = 39 degrees with the horizontal and has a coefficient of kinetic friction u = 0.39. The entire time the massless rope is used to pull the block is pulled parallel to the incline at an angle of theta = 39 degrees (thus on the incline it is parallel to the surface) and has a tension of 68 N. How far up the incline does the block travel before coming to rest (measured along the incline)?
2. Relevant equations
I have answered the following questions and found these values to be correct.
The work done by tension before the block goes up the incline (on the horizontal surface) to be 269.5 Joules
The speed of the block right before it begins to travel up the incline is 6.4392 m/s
The work done by friction after a specific distance of x = 2.1 m up the incline (for x measured along the incline) is -81.171 Joules
The work done by gravity after the block has traveled a specific distance of x = 2.1m (for x measured along the incline) is -168.54 Joules
3. The attempt at a solution
I have attempted to incorporate the above ideas and answers into the solution, but have no idea if any of these answers are relevant to the final question which is to find the total distance traveled by the object up the incline.
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
tiny-tim
tiny-tim is offline
#2
Mar7-12, 05:41 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
hi clesling!
Quote Quote by clesling View Post
I have no idea if any of these answers are relevant to the final question which is to find the total distance traveled by the object up the incline.
yes, use the work-energy theorem
work done = change in mechanical energy
(mechanical energy is KE + PE)
Register to reply
Related Discussions
Crate being pulled at angle, find tension Introductory Physics Homework 1
A block on an incline - What force applied to incline keeps block at equilibrium? Introductory Physics Homework 5
Find max compression of spring, block on incline Introductory Physics Homework 4
Block sliding down incline, hitting another block, find distance. Introductory Physics Homework 0
Block sliding down frictionless ramp while being pulled with constant force? Introductory Physics Homework 9
