Heat of Reaction - Calculations Help
The discussion revolves around the calculations of the heat of reaction for three different chemical reactions involving sodium hydroxide (NaOH) and hydrochloric acid (HCl). Participants seek assistance with the calculations related to these reactions, which include the dissolution of NaOH in water and the neutralization reactions between NaOH and HCl in both aqueous and solid forms. The scope includes theoretical calculations and practical application of thermodynamic principles.
  • Homework-related
  • One participant describes the setup for three reactions, noting the mass and temperature changes involved in each.
  • For Reaction 1, a calculation for deltaH is presented, but the participant expresses uncertainty about the method for Reactions 2 and 3.
  • Another participant suggests using the same approach for Reaction 2 as for Reaction 1, recommending the calculation of moles based on concentration and volume.
  • Further clarification is provided regarding the use of Hess's law to relate the enthalpy changes of the reactions.
  • Participants discuss the implications of limiting reagents in Reaction 3 and how it affects the calculations.
  • There is a suggestion that the heat released from the dissolution of NaOH and the neutralization with HCl should be considered separately in the calculations for Reaction 3.
  • One participant questions whether the calculations for Reaction 3 would resemble those for Reaction 1, indicating confusion about the methodology.
Participants do not reach a consensus on the correct approach for calculating the heat of reaction for all three reactions. There are differing opinions on the application of Hess's law and the treatment of limiting reagents, indicating ongoing debate and uncertainty in the calculations.
Participants express confusion regarding the calculations, particularly for Reactions 2 and 3, and there are indications of missing assumptions or steps in the calculations. The discussion reflects a reliance on specific definitions and conditions that may not be fully articulated.
This discussion may be useful for students studying thermodynamics, particularly those working on calorimetry and reaction enthalpy calculations in chemistry courses.
BH20
Hey
I would really appreciate help on the calculations, because I am just not quiet getting it.
I had 3 different reactions I had to do.
First, some things to note:
Since all the solutions are dilute, then the density of each soltuion can be assumed to be 1.00g/mL. So, 100mL has a mass of 100g.
Reaction 1 was the dissolution of NaOH. So it was 200mL of water. The initial temp was taken, then 5.5g of NaOH was placed in, and a second temp was taken.
Reaction 2 was a heat of reaction between aqueous NaOH and aqueous HCL. 100mL of 1.0mol/L of HCl in a vessel, and the ame of NaOH. Initial temps are taken of each substance. Then, they are mixed together, and the new temp. is recorded.
Finally, Reaction 3 is the heat of reaction between solid NaOH and aqueous HCl. We have 200mL of 1.0mol/L of HCl in a vessel, we record the temp. Then we take 5.5g of NaOH and we pour it into the acid. We then take that new temp.
Of course the equation that is used for Heat or Rection is deltaH = m * deltaT * C.
The calculations are difficult because there is more then that calculation...
Not, for Reaction 1, don't think, this is how I did it:
deltaH = m * c * deltaT
deltaH = 200g * 1cal/moldegcel * 0.00418kj/cal * (13degcel)
deltaH = 10.868kJ
since its 5.5g though:
-10.868kj/0.1375 = -79.04kj/mol
However, Reaction 2 is abit different, and I know its not the same way..and I don't know how to do it. Same with 3.
Any help would be appreciated.
Chemistry news on Phys.org
anybody have any idea?
BH20 said:
Hey
deltaH = 10.868kJ
For your second reaction, just do exactly what you're doing to figure out the delta H. When you get to the number of moles, just use the .1 L * 1 mol/L to figure out the number of moles for either HCl or NaOH. After that again do what you were doing by dividing the deltaH by the number of moles to figure out the enthalpy change per mole of HCl or NaOH.
For your third reaction, again do exactly what you were doing in question 1 for the deltaH. After that take the deltaH you determined and divide it by the number of moles you determined for each reactant to figure out the enthalpy change per mole for HCl and NaOH.
I'm pretty sure this is how you're suppose to figure out the third reaction, but I've only started this unit recently... I hope some one else can help out later on, to see if it was correct or not.
Thanks apchemstudent!
Here is reaction 1 and 2. I think using Hess's law you can figure out what the third reaction answer should be as well. (a way to check if its right) Can someone who knows show me that.
1)
deltaH = 10.868kJ
2)
deltaH = 200g * 1cal/moldegcel * 0.00418kJ/cal * (10degcel)
deltaH = -8.36kJ
-.836kJ/0.1=-83.6kJ/mol
BTW, this is what I did before for Reaction 2. I think you are right, but I figured a neutralization reaction should be lower than the dissolution of NaOH, but guess not.
1)
deltaH = 10.868kJ
2)
deltaH = -8.36kJ
I have somewhat an understanding for Hess's Law:
HCl + Na(+)(aq) + OH(-)(aq) -> NaCl + H2O delta H = ?
NaOH(s) - > Na(+)(aq) + OH(-)(aq) delta H = ?
________________________________________
HCl + NaOH(s) -> NaCl + H2O delta H = ?
You have the molar enthalpy for the both of the reactions and you are given the number of moles already. So multiply the molar enthalpy changes respectively by their correct moles and simply add them, to obtain the correct reaction formula and enthalpy change. I guess for the third reaction you don't have to do figure out the molar enthalpy change... If so you already know how to do that.
ok, but the way I am thinking, wouldn't calculation three look the same as one then?
I have the 5.5g in Reaction 3, so I would be using the moles of NaOH (0.1375)?
Hess's law would be deltaH1 + deltaH2 = deltaH3
Calculation three does not look the same as 1 because it involves the heat released from the dissolution of NaOH(s) and as well it also involves the heat released from the neuatralization of HCl and NaOH(aq).
I made a mistake in my explanation of reaction 3...
Since NaOH is the limiting reagent, then that means .2 - .1375 moles of HCl remains unreacted. I think we're assuming the unreacted HCl does not release any heat.
If we trace each reaction individually:
Step 1: Solid NaOH is turned into ions which also releases heat.
NaOH(s) -> Na(+)(aq) + OH(-)(aq) <--- you've determined the enthalpy change per mole of NaOH(s) so you can figure out the amount of heat released by this reaction.
Step 2: The ions from the NaOH are reacted with HCl(aq) to release even more energy.
Na(+)(aq) + OH(-)(aq) + HCl(aq) -> NaCl + H2O <---- again you've determined the enthalpy change per mole of the NaOH(aq), which was the same as the HCl(aq), but since the NaOH is the limiting reagent, we should use it instead.
Now we have delta H1 + delta H2 = delta H3 to see if it was close to your experimental values.
BH20 said:
Hey
If both reactants (NaOH and water) were at the same initial temperature, the heat of dissolution is simply
[tex]Q_{diss} = m_{tot}C \Delta T[/tex]
Divide this by the number of moles of NaOH (n=5.5/40) to get [itex]\Delta H_{diss}[/itex]
Write the equation for the reaction between NaOH and HCl, and balance it. You'll find that 1 mole of NaOH reacts with 1 mole of HCl completely. Now since your experiment uses 0.1 moles (1 mol/L * 0.1 L) of both, they will both react fully. So, find Q as above, and divide by the number of moles (n=0.1) again, to find [itex]\Delta H_{reac}[/itex]
Start with the balanced equation : it takes one mole of NaOH for 1 mole of HCl. Now clearly, there's 0.2 moles of HCl and 0.1375 (=5.5/40) moles of NaOH. So, only 0.1375 moles of HCl will react with it, the rest is unreacted.
As always, calculate Q from the temperatures, and divide by the number of moles that have contributed to the reaction (ie: 0.1375). This gives you a number representing the sum [itex]\Delta H_{diss} + \Delta H_{reac}[/itex], since both processes are involved here. Within reasonable experimental errors, this number should be the sum of the above two.
deltaH = 200g * 1cal/g.degcel * 0.00418kj/cal * (13degcel)
deltaH = 10.868kJ
This is correct. Just note the small correction I've made (in bold) to the units.
PS : I believe apchem has said the same thing.
13K
25K
