Is the Look-Elsewhere Effect Similar to Playing Pool Without Calling Shots?
  • Context: Undergrad
  • Thread starter Thread starter DragonPetter
    Analogy
The discussion establishes that the look-elsewhere effect in particle physics can be analogously compared to playing pool without calling shots. This analogy highlights that while one may eventually succeed in hitting a ball, it does not reflect skill or intention, similar to how low probability events can occur through repeated experimentation. The concept is further illustrated through the comic from xkcd, which effectively explains the trials factor associated with this phenomenon.
  • Understanding of the look-elsewhere effect in statistics
  • Basic knowledge of probability theory
  • Familiarity with experimental design in physics
  • Awareness of the xkcd comic series for illustrative examples
  • Research the implications of the look-elsewhere effect in particle physics experiments
  • Study the concept of the trials factor in statistical analysis
  • Examine the role of experimental design in minimizing misleading results
  • Explore additional xkcd comics that explain complex scientific concepts
Researchers in particle physics, statisticians, educators in science, and anyone interested in understanding the nuances of probability and experimental results.
DragonPetter
Would it be an appropriate analogy to say that the look else where effect is like shooting pool without calling your shots?
You will eventually hit a ball in if you just keep hitting the cue ball hard enough into all of the balls, but its not because you were aiming for that ball into that pocket and so you can't conclude that you are a good pool player.
Err, sort of. It is really a slightly annoying technical problem quite specific to the way particle physicists have decided to present their results, but it is sort of analogous to the 'trials factor' kind of scenario you present (i.e. that low probability events are quite likely to happen if you repeat your experiment lots of times). This is of course well explained by xkcd: http://xkcd.com/882/
The look elsewhere effect is kind of like a continuous version of this effect.
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 0 ·
