How to mass an object that is less dense than air?
  • Context: Undergrad
  • Thread starter Thread starter Ralphonsicus
    Air Mass
The discussion revolves around methods for determining the mass of objects that are less dense than air, such as balloons. Participants explore various approaches and clarify terminology related to mass measurement in contexts where traditional gravitational methods may not apply.
  • One participant questions the use of the term "massing," suggesting that "mass" is a noun and not a verb.
  • Another participant introduces the concept of buoyancy as a method for weighing less dense objects, referencing external resources for further information.
  • A suggestion is made to weigh the object as if it were submerged in water, implying that this method could yield accurate results.
  • A different approach is proposed, which involves placing the object on a digital scale inside a vacuum chamber to measure its mass without the influence of buoyancy.
Participants express differing views on the terminology used and the methods for measuring mass, indicating that there is no consensus on the best approach. Some methods are proposed, but the discussion remains unresolved regarding the most effective technique.
There is ambiguity surrounding the term "massing" and how it applies to measuring mass in non-standard conditions. The effectiveness of the proposed methods may depend on specific assumptions about the environment and the properties of the objects in question.
Ralphonsicus
How does one go about massing an object less dense than air (like a balloon), because gravity can then not be relied on?
What do mean by "massing"? Note - "mass" is a noun, not a verb.
Buoyancy! This page should help: http://hyperphysics.phy-astr.gsu.edu/hbase/pbuoy4.html#c2
Just pretend you are weighing the object underwater and the page should work fine. If you want to do the calculations by hand you can find them on wikipedia's page on Buoyancy as well as on the first site linked.
Having trouble understanding? Drakkith seemed to cope just fine.
Thanks, just what I was looking for.
It's important to always be clear as to what you are asking.
Place the object on a digital scale inside of a vacuum chamber.
  • · Replies 18 ·
  • · Replies 59 ·
  • · Replies 17 ·
26K
  • · Replies 18 ·
  • · Replies 21 ·
