Find the Density of an Object Immersed in Water & Oil: 32.142857kg/5.612246m3
  • Thread starter Thread starter Sny
    Fluids
The discussion revolves around calculating the density of an object based on its weight in air and when submerged in water and oil. The subject area includes principles of buoyancy and density calculations.
  • Exploratory, Assumption checking
  • The original poster attempts to calculate the density using the weight measurements and the volume derived from the apparent mass when submerged. Some participants question the calculations of the volume and the differences in weight readings.
The discussion is ongoing, with participants exploring discrepancies in the calculations and questioning the accuracy of the values obtained. There is no explicit consensus, but participants are engaged in clarifying the numerical results.
There are indications of potential calculator errors and confusion regarding the correct values for weight differences, which may affect the calculations being discussed.
Sny
An object weighing 315 N in air is immersed in water after being tied to a string connected to a balance. The scale now reads 260 N. Immersed in oil, the object weighs 275 N. Find the density of the object in kg/m3.
I found the mass of the object to be 32.142857kg and the apparent mass when submerged to be 26.530611kg. This means the volume would be 5.612246, because the volume of the object is the volume of the displaced water, thus giving me the mass and volume. So, 32.142857/5.612246 is 5.73, yet the answer keeps coming up wrong. What am i doing wrong?
Would it surprise you to know that 32.142857- 26.530611= 6.612246, not 5.612246?
Yes, because my calculator's telling me otherwise :eek:
Huh?? I got 5.612246 with calculator and by hand. Maybe you pushed a worng button by mistake when you did it.
  • · Replies 62 ·
  • · Replies 20 ·
12K
  • · Replies 17 ·
  • · Replies 16 ·
