Register to reply
Can someone help me with this static friction problem?
by shaggyace
Tags: friction, static
Share this thread:
shaggyace
#1
Mar12-12, 03:51 PM
P: 11
A 45-kg crate is placed on an inclined ramp. When the angle the ramp makes with the horizontal is increased to 24 degrees , the crate begins to slide downward. What is the coefficient of static friction between the crate and the ramp?
2. Relevant equations
[itex]\Sigma[/itex]F=ma
fs=[itex]\mu[/itex]sN
3. The attempt at a solution
I started by drawing a free body diagram. My weight came out to be -441 N. I have the angle of my weight at 24 degrees. The normal force at mgcos24, for which I got 187N. mgsin24 came out to be 399N which is also the static friction force. Then I just substituted into the static friction equation and my coefficient of static friction came out to be 2.13. I entered this into the homework problem which we do online and it is wrong. Did I miss a step? What did I do wrong?
Phys.Org News Partner Science news on Phys.org
Flapping baby birds give clues to origin of flight
Prions can trigger 'stuck' wine fermentations, researchers find
Socially-assistive robots help kids with autism learn by providing personalized prompts
tal444
#2
Mar12-12, 04:01 PM
P: 157
Your values for mgcos24 and mgsin24 are incorrect. Your calculator appears to be in radian mode.
emailanmol
#3
Mar12-12, 04:06 PM
P: 297
The applied formula is right.The math is wrong.
the weight u calculated using m as 450 and g as 9.8 (all in SI units) is right as 441 N.
As u said normal force is mgcos24.
and mgsin24 as component of weight parallel to inclined plane.
However, the calculated values are not right.
Hint(for angles less than 45 degrees cos x is always greater the sin x.
However, here your mgcos24 is less than mgsin24)
shaggyace
#4
Mar12-12, 04:08 PM
P: 11
Wow, thanks a lot Calc class, lol.
Got the answer, thanks for your help guys
Register to reply
Related Discussions
Friction problem with banked curve given static friction coefficient Introductory Physics Homework 3
Static friction problem Introductory Physics Homework 6
Static Friction Problem Introductory Physics Homework 10
SHM - problem with static friction Introductory Physics Homework 3
A Static friction problem Introductory Physics Homework 4
