New Reply
Uncertanty in double slit diffraction
Share Thread Thread Tools
Mar13-12, 12:32 AM   #1
In a double-slit experiment electrons are sent through a doule slit where an indicator determines the slit each electron went through. These indicators tell the y coordinate to within d/2, where d is the distance between the slits. If this is the case show that the diffraction pattern will be destroyed.
The angular distance,Δθ, between a maximum and minimum is λ/(2d). The angular distance may also be approximated as Δy/l where l is the distance from the slits to the screen. The y seperation,Δy, at the screen between a max and adjacent minimum is (λl)/(2d).
I understand that in order for the pattern to be destroyed the uncertainty in the y position at the screen must be equal to the distance between adjacent min and max, but I can't seem to get there.
The uncertainty of y at the slits is given in the problem as d/2 allowing the momentum in y to be found. Assuming the uncertainty in p at the slit is the same at the screen then Δp is known. Assuming the electron has a momentum in the x direction then the momentum in x and the wavelength may be used. I tried to say that Δθ=Δy/l, and then substitute the p relation in for y but this gets me no where. Messing around I found out that setting Δy/l=Δpy/px and solving for Δy gives the correct relation but I have no idea why you can set these two things equal to each other.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
New Reply
Tags
diffraction, double slit, quantum, uncertainty
Thread Tools
Similar Threads for: Uncertanty in double slit diffraction
Thread Forum Replies
Double Slit Diffraction Introductory Physics Homework 2
Double Slit Diffraction Introductory Physics Homework 4
Double slit diffraction General Physics 2
Double Slit Diffraction Advanced Physics Homework 1
