Solve Word Problem: Jane Running at 5.6 m/s, How High Can She Swing?
  • Thread starter Thread starter ccf788
    Word problem
Jane, running at a speed of 5.6 m/s, can swing upward to a height of 5.6 meters after grabbing a vine. The solution utilizes the conservation of mechanical energy principle, where Jane's initial kinetic energy (KE) is converted entirely into gravitational potential energy (PE) at the peak of her swing. The relevant equations include KE = 1/2mv^2 and PE = mgh, allowing for the cancellation of mass and gravitational acceleration, leading to the conclusion that the height she can achieve is equal to her initial speed in meters.
  • Understanding of kinetic energy (KE) and potential energy (PE)
  • Familiarity with the conservation of mechanical energy principle
  • Basic knowledge of gravitational acceleration (9.8 m/s²)
  • Ability to manipulate algebraic equations
  • Study the principles of conservation of energy in physics
  • Learn about kinetic and potential energy calculations
  • Explore real-world applications of energy conservation in mechanics
  • Investigate the effects of varying mass on energy conservation outcomes
Students studying physics, educators teaching energy concepts, and anyone interested in solving mechanics-related word problems.
ccf788
Jane, looking for Tarzan, is running at top speed (5.6 m/s) and grabs a vine hanging vertically from a tall tree in the jungle. How high can she swing upward?
I know the answer is 1.6 m, but I don't understand how to get it.
In class, we have been using the equation: 1/2mv^2 + mgy = 1/2mv^2 + mgy (where the first pt. of the equation is v1 and y1, and the second pt. v2 and y2. I don't understand how you would solve it if 5.6 m/s is the only number you have. I think it has something to do with gravity, but I'm not sure what.
Please show me how to solve it. Thanks!
Define potential energy to be zero at the point just below the vine when it is vertical...ie this is the reference point. So initially, Jane's KE can be calculated from her velocity as she grabs the vine, and her PE is zero. When she swings upward, her KE is converted to gravitational potential energy. At the top of her swing, all of it has been converted, her velocity is zero, so she can go no further. Assuming only conservative forces, we can use conservation of mechanical energy as you suggested, except that based on what I said, it is in this form:
1/2mv2 + 0 = 0 + mgy
Solve for y
To solve this word problem, we can use the equation for potential energy: PE = mgh, where m is the mass of the object, g is the acceleration due to gravity (9.8 m/s^2), and h is the height.
In this case, we know that Jane is running at a speed of 5.6 m/s and then grabs onto a vine. At this point, her velocity becomes 0 m/s since she is no longer moving horizontally. This means that her initial and final velocities are both 0 m/s.
Using the equation for conservation of energy, we can set the initial kinetic energy equal to the final potential energy:
1/2mv^2 + mgy = 1/2mv^2 + mgh
Since her initial and final velocities are both 0 m/s, we can cancel them out of the equation:
mgy = mgh
We also know that the mass of Jane (m) is the same on both sides of the equation and can be cancelled out. This leaves us with:
gy = gh
Since g is the same on both sides of the equation, we can also cancel it out:
y = h
This means that the height (h) that Jane can swing upward is equal to the initial height (y) that she starts at. Since she is running at a speed of 5.6 m/s, she can swing up to a height of 5.6 meters. This is because at the highest point of her swing, all of her initial kinetic energy has been converted into potential energy due to gravity.
Therefore, the answer is 5.6 meters. I hope this helps to clarify how to solve this word problem using the equation for conservation of energy. Let me know if you have any further questions.
12K
