What are the Critical Numbers for f(x) = 2x^3 + 15x^2 - 36x +1?
  • Thread starter Thread starter ziddy83
    Numbers
The discussion revolves around finding the critical numbers for the function f(x) = 2x^3 + 15x^2 - 36x + 1. Participants are exploring the definitions and methods related to critical numbers in the context of calculus.
  • Conceptual clarification, Mathematical reasoning
  • Participants discuss the definition of critical numbers and whether a second derivative is necessary for finding them. There is a focus on setting the first derivative equal to zero to find solutions.
The discussion is active, with participants clarifying definitions and confirming that the first derivative can be set to zero to find critical numbers. There is an acknowledgment of differing terminology regarding critical numbers and critical points.
Some participants question the terminology used in the problem, noting differences between "critical numbers" and "critical points." There is also a mention of ensuring that the derivative does not exist for certain values of x.
ziddy83
Hi,
i was wondering if anyone could help me.
The problem says find the critical numbers of f...
ok i found f ' ...6x^2 + 30x-36,
Now how do i start on finding the critical numbers? Do i have to take the second derivative?
What, exactly, is the definition of "critical number?" :-)
Definition of a Critical Number
Let f be defined at c. If f'(c) = 0 or f' is undefined at c, then c is a critical number of f.
So should you take a second derivative?
Right...its not, so I can just set it equal to zero, and then solve for the variable, right?
Yes,your 'critical numbers' are solution of the equation
[tex]f'(x)=0[/tex]
.BTW,your terminology is pretty weird.I use to call them "critical points",coz they pop up whenever i want to draw the graph of a function
Daniel.
"Right...its not, so I can just set it equal to zero, and then solve for the variable, right?"
Having determined first that there are no values of x for which the derivative does not exist, yes.
"BTW,your terminology is pretty weird.I use to call them "critical points",coz they pop up whenever i want to draw the graph of a function"
Actually, there is a difference. Given y= f(x), the "critical numbers" are the values of x at which f ' (x) does not exist or is equal to 0. The "critical points" are the points (x,y) with x a critical number.
  • · Replies 29 ·
  • · Replies 17 ·
  • · Replies 16 ·
