Register to reply
Rate of Deceleration & Magnitude of Force
by drsponge
Tags: deceleration, force, magnitude, rate
Share this thread:
drsponge
#1
Mar14-12, 05:29 PM
P: 7
I'm not entirely sure of my answer, if it's wrong could some one point me in the right direction?
A 140g ball is falling through the air at 36 meters per second (constant speed) prior to time 0.
The ball impacts the floor at time 0. The ball decelerates until time 0.012. At this time ball has come to rest.
Between time 0 and time 0.012 what is the rate of deceleration?
Then using this data calculate the magnitude of the force exerted by the floor.
2. Relevant equations
Deceleration = initial speed minus final speed divided by time.
36 m s-1 - 0 m s-1 / 0.012 s
= 3000 m s -1
Calculate the magnitude of the unbalanced force exerted by the floor.
F = ma
F = 140g x 36 m s-1 = 5040 newtons.
OR IS IT
F = 140g x 3000 m s-1 = 420,000 newtons.
3. The attempt at a solution
The solution would be 5040 newtons was being exerted by the floor. But is this correct? I under stand that acceleration is a CHANGE in velocity with in time. If the speed is constant until there is no acceleration only deceleration after the impact?
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
tiny-tim
#2
Mar14-12, 06:34 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
hi drsponge! welcome to pf!
(try using the X2 button just above the Reply box )
Quote Quote by drsponge View Post
= 3000 m s -1
you mean 3000 m s-2
F = ma
OR IS IT
i] newton is an SI (kgs) unit, so you must convert all masses to kg
ii] it's 3000 m s-2
so the question is, should you be using m s-1 or m s-2 ?
iii] what about gravity?
drsponge
#3
Mar15-12, 02:24 AM
P: 7
Oh yes, s-2 would be correct.
The ball weighs 140g or 0.14kg. It is travelling at a constant speed of 36 m s-1 until impact with the floor at point 0.
The change in acceleration is 36 m s-1 minus 0 m s-1 over 0.012 s which means the change in acceleration is 3000 m s-2
Therefore the force exerted by the floor is
F = 0.14kg x 3000 m s-2
= 420 N
In regards with gravity if the ball is falling with a constant velocity it must have reached it's terminal velocity so gravity and drag / air resistance are equal before impact.
tiny-tim
#4
Mar15-12, 02:34 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
hi drsponge!
yes, but drag disappears when the ball hits the floor, while gravity doesn't disappear!
there are two forces on the ball, that make up Ftotal = ma
the normal force N from the floor,
and the weight W = mg from the Earth
drsponge
#5
Mar15-12, 03:11 AM
P: 7
Thanks Tim,
Ahh so the net force is F2 because W = mass (0.14kg) x gravity (9.8 m s2) is acting on the ball and so is the force exerted by the floor in N.
W = 1.37kg
N = 420
Since 1 N = 1 kg m s-2
Therefore the forces are unbalanced because the floor is exerting more force than gravity which halts the balls progress.
tiny-tim
#6
Mar15-12, 05:24 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
yes
since we're using two significant figures, it makes no difference, but if we were using three, then the normal force would be 421 N
drsponge
#7
Mar15-12, 01:07 PM
P: 7
Hi Tim,
Thanks very much for all your help. I think I've managed to safely file this away in my brain. I'm starting out on a science qualification towards a degree eventually. First time I've even attempted science academically for 10 years or so.. I'm rusty.
Register to reply
Related Discussions
I cant solve a simple Acceleration/Deceleration rate of time problem. Introductory Physics Homework 3
Deceleration rate General Physics 3
Displacement with magnitude of deceleration Introductory Physics Homework 7
Rate of Deceleration General Physics 13
Magnitude of deceleration Introductory Physics Homework 7
