| Thread Closed |
Is gravitation faster than light? |
Share Thread | Thread Tools |
| Jan20-05, 05:25 PM | #52 |
DB, the bowling ball/rubber sheet analogy is in two dimensions bent in a third; but the reality is four dimensions on a manifold. Thus, if you use only the analogy, it will break down and give you wrong understanding sometimes.
| Jan20-05, 06:15 PM | #53 |
| Jan20-05, 06:21 PM | #54 |
To clarify something that's been rather, shall we say, elided in many posts in this thread.
'Gravitational radiation' aka 'gravitational waves' are a direct consequence of GR; to the extent that no good observational or experimental data to date is inconsistent with GR, so we can expect that these are 'real'. 'Gravitons' are NOT part of GR; they require some 'quantum' theory compatible with GR. To date, AFAIK, there is NO observational data that even hints at what form a quantised form of GR should take (so theorists can - and do - imagine anything they like!). Re black holes: there is very good observational data consistent with the existence of stellar mass (and above, to billion sol) BHs; the extent to which these 'behave' like GR, QM, of Nereid's pet ideas is entirely unconstrained by good observational data (at this time). |
| Jan20-05, 08:26 PM | #55 |
Recognitions:
For gravity, it's a bit more complicated, Steve Carlip says here that it depends on the quadrupole term in a multipole expansion rather than the dipole term as in electromagnetism, so gravity can "anticipate" the orbits of planets as well as linear motion--see this page for more info: |
| Jan20-05, 09:23 PM | #56 |
Thanks for the detailed clarifications, Jesse.
| Jan21-05, 03:53 AM | #57 |
(b) It provides an idea for actual cause for gravity. (c) It quite unashamedly assumes an aether, not just letting one creep in by the back door. Of couse it is not much use as a "theory" because of its lack of equations, but it does make a few qualitative predictions. For more see my web site. I have been cautioned not to try and introduce personal theories on this forum, otherwise I'd say more here. Caroline http://freespace.virgin.net/ch.thompson1/ |
| Jan21-05, 07:39 AM | #58 |
I think you started posting here after the big discussion we had on the extent to which we would encourage, support, or even allow qualitative personal ideas in the 'science' parts of PF (the Theory Development section used to be one of the most active parts of PF!). Never mind; the decision was to strongly discourage these, unless they are 'nearly ready for prime time' (e.g. been accepted for publication in a peer-reviewed journal). On the other hand, critiques of 'mainstream' physics - especially in the form of penetrating questions and showing (apparent) internal and external inconsistencies - is very much to be encouraged!
| Jan21-05, 05:11 PM | #59 |
Well, thank you all for your posts!
I will no be able to answer quickly to all of them, but here is the most important one for me: At least virtual gravitons are able to move faster than c to escape the event horizon. Is this also true for virtual photons in an EM field? That implies, that information can leave a black hole, correct? Carsten |
| Jan21-05, 05:58 PM | #60 |
Recognitions:
| Jan22-05, 02:15 PM | #61 |
Incidentally, surely light does dissipate just a tiny bit, otherwise the night sky would be bright (Olbers' paradox)? What experimental evidence do we have that forces don't dissipate similarly over similar distances? In my Phi-Wave-Aether theory, the high-level patterns get smudged out so that radiation and the forces lose their effectiveness. The net intensity of the phi-waves, though, almost certainly stays the same. On the scale of the whole universe, there is conservation of "phi-energy". Caroline http://freespace.virgin.net/ch.thompson1/ |
| Jan22-05, 05:22 PM | #62 |
(Even more interestingly, it appears that while a field is not made up of anything, a wave can be considered to be made up of something, specifically quanta; and these quanta reveal their presence by the contrafactuality of the "violet catastrope," and by the reality of the photoelectric effect, at least in the case of the quanta of the electromagnetic interaction. I have still not finished considering the implications of this with regard to the field, nor the implications with regard to string physics.) A wave is not a field, but the variation of a field. In order for a field to vary, the source of the field must accelerate (not merely move, but accelerate). In the absence of acceleration, there is no wave. In the absence of expenditure of energy, there is no acceleration. Thus, for a wave to be formed, an object that is the source of a field must accelerate; and for an object to do this in the absence of a source of energy is, as I said, a violation of the conservation of mass/energy. In regard to Olbers' paradox, there are several different possible solutions, and the most widely accepted one is that the universe is not infinite in time. This solution has the advantage over your proposed solution that it does not contradict well-known experimental results. Brightness observations on stars conform to the inverse-square law, which is the result of the geometry of spacetime. These brightness observations are consistent for particular types of stars, and the distance to the stars is established using simple geometric techniques (see Hipparcos and Tycho data, which establish the distances to millions of stars geometrically with error bars indicating accuracies better than ten significant figures). If the electromagnetic force were to dissipate over distance, we would observe that stars of a given type that were further away would be uniformly less bright than stars of the same type that were closer, and we do not observe this. The Herzsprung-Russell diagram is proof of this fact. Rotation observations of the planets in the Solar System would be affected by any dissipation of gravity over distance, requiring an ever-increasing correction for each planet successively further from the Sun; this correction is not observed. Therefore, the electromagnetic and gravity fields are not affected by any "dissipation" of their strength over spatial distances, and there is observational evidence to supplement laboratory experiment evidence that this is true. |
| Jan23-05, 07:47 AM | #63 |
Hi Schneibster,
May I still continue to “bug you” with a couple of questions? Carsten |
| Jan23-05, 08:15 AM | #64 |
There have been several good discussions on gravitation and its speed in the Special & General Relativity section of PF; do readers feel this thread should be moved there (it'd get the attention of folk who are very familiar with GR). |
| Jan23-05, 09:50 AM | #65 |
Hi Nereid,
Thanks for the details! Carsten |
| Jan23-05, 11:51 AM | #66 |
At the quantum level, we know that everything is constantly changing. We know that "interference" phenomena are important. To me, this implies that at that level there are high-frequency waves, underlying all the forces and causing everything that we see. "The Phi-Wave Aether: a Wave Theory of Everything", http://freespace.virgin.net/ch.thomp...colApeiron.pdf or html version: http://freespace.virgin.net/ch.thomp...WA.Apeiron.htmCheers Caroline |
| Jan23-05, 04:01 PM | #67 |
with all respect to your theory, but first of all, I would like to understand how science explains our universe. And secondly I would like to understand where it still has frontiers in explaining it. Can you help us/me in the questions of this thread? But I would like to hear no speculations at this time but only the widely accepted theories. Everything else is confusing at this point. I am very open to new ideas, but let us first understand the facts. And afterwards, I am happy to open a new thread on speculations. Best regards, Carsten |
| Jan23-05, 05:05 PM | #68 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Is gravitation faster than light?
| Light speed....Impossible Faster than light..Probable? | General Physics | 5 | ||
| Speed of light Schmeed of light: things can travel faster | Special & General Relativity | 13 | ||
| What happens if you go faster than light? | General Physics | 22 | ||
| faster than light-yes -but how? | General Physics | 5 | ||
| gravity faster light?/new ideas light! | General Physics | 2 | ||
