New Reply
Magnetic Force in a Current Carrying Wire
Share Thread Thread Tools
Mar14-12, 09:44 PM   #1
The current in a wire consists of n electrons per unit volume moving with a velocity v. What is the effect on these electrons of the magnetic field set up by the current itself within the wire? What is the force on one electron at a distance r from the centre of the wire?
2. Relevant equations
F = QvBsinθ
Magnetic field strength at a distance r from the axis of the wire outside the wire = u0I/2∏r
3. The attempt at a solution
I know that for part 1, the effect of the magnetic field on the electrons inside the wire will be a radially outward force (taking all electrons to be travelling in straight lines along the wire).
Part 2
F will be equal to QvBsin90 = QvB
Making the subsitution for B I have
F = Qvu0I/2∏r
I believe now that I have to make subsitution for I. Which would be 4/3∏a3vne
where e is fundamental charge and a is the radius of the wire.
This gives:
F = (3/8)u0ve2na3r
I know that the answer is:
F = (1/2)u0v2e2nr
I think I'm making a mistake in calculating my current, but I'm not sure. Help Please?
Thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Mar15-12, 12:14 AM   #2
Hi! This is my first time helping someone out so here goes:
To make the substitution for current I, you should use:
[itex] I=\int J \bullet da [/itex]
where J is the current density, equal to nev in this case. After doing a quick integration you should get the proper current which will give the correct answer for the force.
New Reply
Thread Tools
Similar Threads for: Magnetic Force in a Current Carrying Wire
Thread Forum Replies
Rod of current wire exerting magnetic force on current carrying bar Introductory Physics Homework 0
Magnetic force on a current carrying wire General Physics 2
Magnetic Force on a Current Carrying Wire Introductory Physics Homework 3
Magnetic force for a current-carrying wire Introductory Physics Homework 5
Magnetic Force on A Curved Current Carrying Wire Introductory Physics Homework 2
