New Reply
Can a diode light up when it's connected backwards?
Share Thread Thread Tools
Mar15-12, 10:00 AM   #1
Recognitions:
Gold Membership Gold Member
Trying to find the answer to the question if a regular basic LED diode can light up when it's connected backwards? I even made a lil' sketch
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
>> NASA: Austin, calling Austin. 3-D pizzas to go
Mar15-12, 10:16 AM   #2
The only way that LED will light up is if the battery voltage exceeds the breakdown voltage of the LED and it destroys itself in a bright flash. :)
The short answer to your question would be NO!
Mar15-12, 10:33 AM   #3
Mentor
Just to complement what was already said: the whole point of a diode is that it is a device that conducts current in only one direction and not the other.
Mar15-12, 10:48 AM   #4
Math 2012
Recognitions:
Actually the question of whether you could physically make a light emitting zener diode is interesting (and I don't know the answer).
But conventioal diodes usually self-destruct very fast if you try to operate them in the Zener region, because the Zener voltage is high (typically hundreds or thousands of volts) so the heat generated in the diode (volts x amps) when the Zener current starts to flow is also high.
So the answer is "no" for any "mass produced" LED.
Mar15-12, 11:20 AM   #5
Reverse biasing LEDs isn't all bad...
a reverse biased LED becomes a photo-diode/light-dependent capacitor.
http://www.edn.com/contents/images/81601di.pdf
http://cs.nyu.edu/~jhan/ledtouch/index.html
http://forums.parallax.com/showthrea...D-Touch-Sensor
Mar15-12, 11:22 AM   #6
Well I had one that did, but I think that the manufacture connected the LED backwards when it was manufactured.
Mar15-12, 11:48 AM   #7
Some red LEDs will light up green when connected backwards. There are actually two diodes in the package, wired back to back. See http://www.radioshack.com/product/in...ductId=2062549
Bob S
Mar15-12, 12:52 PM   #8
Mentor
Quote by Bob S View Post
Bob S
But this can be regarded as a set of two LEDs wired in "inverse parallel" (i.e. cathode-to-anode and anode-to-cathode) correct?
Either way, whichever one is active is forward-biased
Mar15-12, 05:02 PM   #9
Recognitions:
So if I have this decoder ->
Current can only flow backwards? I thought the point of a decoder is that signals flow based on the signals defined in A0, A1, and A2. But in this case no signal can be received because the LEDS are blocking the way
Mar15-12, 05:08 PM   #10
Recognitions:
Homework Helper Homework Help
Quote by Femme_physics View Post
http://img33.imageshack.us/img33/5601/decoderd.jpg
Not quite.
At the Q connections the voltage is either high or low.
If the voltage is low, the corresponding LED lights up, with current flowing from Vcc to the low voltage Q connection.
Mar15-12, 05:11 PM   #11
Recognitions:
Ah, so the current flows FROM Vcc, into the LEDS, to the decoder, and eventually leaves as possibly A0, A1, A2 or possibly neither depends on the combination chosen?
Mar15-12, 05:14 PM   #12
Recognitions:
No. A0, A1, and A2 are inputs.
The decoder will have separate connections to a voltage supply that is not shown in your drawing (just like an op-amp).
Mar15-12, 10:37 PM   #13
If you change your dc supply to an ac one, it will ;)
Mar16-12, 02:42 PM   #14
Recognitions:
Quote by I like Serena View Post
Such as...
Mar16-12, 03:11 PM   #15
Recognitions:
Yes, but the Decoder with have extra 2 connections instead of just one.
One to Vcc, and one to -Vcc or earth.
Btw, I have a little trouble with you naming them Vin and Vout.
Mar16-12, 05:36 PM   #16
Recognitions:
T 07:42 PM
Heh, do you?
Well, current has to come in of somewhere and come out to somewhere, so I figured Vin and Vout are the best choices.
Mar16-12, 05:42 PM   #17
Recognitions:
Yeah well, my problems are:
1. Vin and Vout are not currents but voltages.
2. Vin is usually the input signal (in your case you have 3 input signals: A0, A1, and A2) and not the power supply.
3. Vout is usually the output signal (in your case you have 8 output signals: Q0, Q1, ..., Q7) and not the power supply.
New Reply
Thread Tools
Similar Threads for: Can a diode light up when it's connected backwards?
Thread Forum Replies
Diode voltage drop (connected in parallel with a resistor) Electrical Engineering 14
Help: Diode doesn't behave as it should when connected to coil Electrical Engineering 9
Zener Diode connected in serie Electrical Engineering 6
Diode Connected Nmos question Electrical Engineering 0
Light going backwards? General Physics 1
