Which Particle Physics Textbook is Better for a Master's Degree Student?
The discussion revolves around recommendations for particle physics textbooks suitable for a master's degree student, focusing on experimental approaches. Participants compare "Introduction to High Energy Physics" by Perkins and "Particle Physics" by B.R. Martin & G. Shaw, while also considering other options.
  • One participant seeks advice on choosing between Perkins and Martin & Shaw for a master's level textbook in particle physics.
  • Another participant shares their experience with Martin & Shaw, describing it as comprehensive and suitable for introductory levels, noting it includes solutions for self-study.
  • A different recommendation is made for Griffiths' "Introduction to Elementary Particles," which is suggested to have better explanations and to introduce basic Quantum Field Theory, although it may be more advanced.
  • One participant expresses a negative opinion about Perkins, describing it as annoying to learn from.
  • Another participant highlights that Martin's book is up to date as an advantage.
  • A link to an external resource is provided for further exploration.
Participants express differing opinions on the suitability of Perkins, with some recommending it and others advising against it. There is no consensus on which textbook is definitively better, as multiple viewpoints are presented.
Participants do not provide detailed comparisons of the content or structure of the textbooks, and there is a lack of consensus on the appropriateness of Perkins for the intended audience.
Master's degree students in particle physics or those interested in selecting appropriate textbooks for advanced studies in the field.
welatiger
Hi all;
I will work master's degree in particle physics and I want an experimental textbook for particle physics, and i have two choices
is "Introduction to high energy physics" by Perkins
or "particle physics" by B.R. Martin & G. Shaw
Can you advise me
I haven't used Perkins myself so I can't say anything about it, but Martin&Shaw I've used. It is quite nice and often comprehensive and contains most of what you need on an introductory level (basic QM is probably all you will need). It also has solutions to all problems which is nice if you use it for self study.
However, I would instead recommend Griffiths "Introduction to Elementary Particles". It is better than the other in my opinion, better explanations of the concepts in the comprehensive style of Griffiths. It is a bit more advanced than the previous two (don't know about Perkins as I said) since it also introduces a basic form of Quantum Field Theory to be able to calculate cross sections, but it covers the same concepts (at least as Martin&Shaw).
thank you so much
i think that Martin's book advantage is it is up to date
13K
