What causes sand to get hotter then water?
  • Thread starter Thread starter jjjsarnis
    Water
The discussion centers on why sand becomes hotter than water on a sunny day, attributing this phenomenon to the differences in specific heat and thermal conductivity between the two materials. Sand has a lower specific heat, meaning it requires less heat to increase its temperature compared to water. Additionally, the low thermal conductivity of sand, primarily due to poor thermal contact between grains, results in a slower heat dissipation, allowing sand to maintain higher temperatures than water under direct sunlight.
  • Understanding of specific heat capacity
  • Knowledge of thermal conductivity principles
  • Basic concepts of heat transfer
  • Familiarity with calculus and differential equations for modeling heat transfer
  • Research the specific heat capacities of various materials, including sand and water
  • Explore thermal conductivity comparisons among different substances
  • Study heat transfer mechanisms in solids and liquids
  • Learn how to model heat transfer using calculus and differential equations
Students in physics or environmental science, educators teaching heat transfer concepts, and anyone interested in understanding thermal properties of materials.
jjjsarnis
question: on a sunny day at the beach, the reason the sand gets hot and the water stays relatively cool is attributed to the fdiffernce in which property between water and sand?
is it specific heat or thermal conduvtivitiy??
our class and our teacher argued over this all class, thanks for your help
Both.
The low specific heat ensures that something receiving a smaller heat flux gains a larger increase in temperature. The low conductivity (which is mostly due to the poor thermal contact between sand grains) ensures that the temperature gradient created can be large for a given rate of downward heat removal.
In other words :
First the surface layers of water and sand get heated directly by the sunlight. If none of this heat is conducted away, the sand will reach a higher temperature than water because of the lower specific heat. However, the heat does get conducted away. But again, since it is conducted away more slowly by the sand, than by the water, the surface of the sand stays hotter.
With calculus (differential equations), this can be modeled reasonably easily.
Gokul43201 said:
Both.
I agree with the low specific heat point. To undergo a temperature increase of one degree, the sand requires much less heat than water. So the same amount of heat/unit area incident upon sand and upon water will increase the temperature of the sand much more.
But I am not sure about the thermal conductivity. Its thermal conductivity is the same as sawdust and I don't think sawdust would feel as hot as sand if you set them out in the sun.
AM
  • · Replies 32 ·
28K
  • · Replies 67 ·
