Does the buoyant force change in different fluids?
The buoyant force acting on an object does not remain constant across different fluids, as established by Archimedes' principle. When two objects of identical density and weight float in water and saltwater, respectively, the object in saltwater displaces less fluid and thus experiences a different buoyant force. While both objects float in equilibrium, the buoyant force is contingent upon the volume of fluid displaced, which varies between freshwater and saltwater. Therefore, the buoyant force is greater in freshwater due to the larger volume displaced compared to saltwater.
  • Understanding of Archimedes' principle
  • Knowledge of fluid density differences
  • Basic concepts of buoyancy and equilibrium
  • Familiarity with the properties of saltwater versus freshwater
  • Research the mathematical formulation of Archimedes' principle
  • Explore the effects of fluid density on buoyant force calculations
  • Study real-world applications of buoyancy in engineering
  • Investigate the impact of temperature and salinity on fluid density
Students of physics, engineers working with fluid dynamics, and anyone interested in the principles of buoyancy and fluid mechanics.
jayadds
Given two objects of identical density and weight, one is floating on water and the other is floating on saltwater. Is the magnitude of buoyant force acting on the object the same in the two situations? From my thinking, it seems that the weight of the object in the the two situations should not change and so the buoyant force should not change as well (Archimedes principle). Correct me if I'm wrong in that thinking.
Thanks
If both objects are floating in equilibrium, the upwards force on each object (buoyant force) must be equal to the downwards force (weight), so you are correct.
The buoyant force is equal to the weight of the amount of fluid displaced, so the object floating on saltwater will displace less fluid and therefore float higher than the object floating on pure water.
However, if the object was fully immersed in water, then the buoyant force WOULD be different.
  • · Replies 17 ·
11K
