New Reply
Solution Needed to combine Thrust, Torque and Motion?
Share Thread
Mar16-12, 03:51 AM   #1
I have a problem which I cannot crack, I am currently looking into the use of a universal joints but I want to explorer other routes too.
I am working on a gearbox test rig which requires a means of transmitting a thrust (5000 N), a torque (1800 Nm) and a speed (2000 RPM) all in the same "shaft". There is also a requirement for a 32mm rod to travel through the middle of all this.
I also need a means of providing the thrust load, currently the use of a Hollow Hydraulic Cylinder looks to be the most effective solution.
Space constraint of the system (length) is around 14".
The input side will be attached to a spline, the thrust load will have to be applied to this splined shaft, the output end is open to ideas.
Many Thanks!
Steve
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
New Reply
Tags
gearbox, mechanical, testing
Similar discussions for: Solution Needed to combine Thrust, Torque and Motion?
Thread Forum Replies
solution for x^3-x=y needed, is solution an approximation? General Math 2
Stuck with calculating torque needed for Robot servo motion Mechanical Engineering 3
Thrust needed for Orbit of a satellite Advanced Physics Homework 5
motion solution needed Engineering Systems & Design 3
Equilibrium Torque help needed Introductory Physics Homework 1
