Thermodynamics : Heat transfer question.
The discussion focuses on a thermodynamics problem involving heat transfer between a solid body X and a large box Y, utilizing Newton's Law of Cooling. The initial temperature of body X is 400K, which cools to 350K at time t1 while in a 300K environment. The problem requires calculating the temperature of body X at time t=3t1 after connecting it to box Y through a conducting rod characterized by thermal conductivity K, length L, and cross-sectional area A. The relevant equations include Newton's law of cooling and the heat transfer equation H = KA/L dT.
  • Understanding of Newton's Law of Cooling
  • Familiarity with heat transfer concepts, specifically conduction
  • Knowledge of logarithmic functions and integration techniques
  • Basic principles of thermodynamics and heat capacity
  • Study the derivation and application of Newton's Law of Cooling in various scenarios
  • Explore the principles of heat conduction, focusing on Fourier's Law
  • Learn about thermal conductivity and its impact on heat transfer rates
  • Investigate the effects of radiation heat transfer in thermodynamic systems
Students studying thermodynamics, engineers working on heat transfer problems, and anyone interested in the practical applications of Newton's Law of Cooling in real-world scenarios.
AlchemistK
A solid body X of heat capacity C is kept in an atmosphere whose temperature is 300K. At t=0 temperature of X is 400K. It cools according to Newton's Law of cooling.
At time t1 its temperature is found to be 350 K .
At this time,the body X is connected to a large box Y at atmospheric temperature through a conducting rod of length L, cross sectional area A and thermal conductivity K.
The heat capacity of Y is so large that any vibration in its temperature rod is small compared to the surface area of X.
Find temperature of X at time t=3t1
Newton's law of cooling : dT/dt = -(4eσAT°3)ΔT/ms
On integrating to calculate the time it takes for the body to reach a temperature T2 from T1:
t=(ms/4eσAT°3) ln ((T1 - T°)/ (T2 - T°))
H = KA/L dT
Now first, the box reaches the temperature of T=350K in t1 time
So, ti = (ms/4eσA°*3003) ln ((400 - 300)/ (350 - 300))
= (ms/4eσA°*3003) ln 2
Now after this, a rod is connected to it, at this point I don't know if I have to consider only heat transfer through the rod, or also by radiation into the atmosphere.
Also, how do I proceed in either case?
Please define your symbols.
