How Do You Conduct Chemical Tests to Identify an Unknown Acid?
  • Thread starter Thread starter thick1
    Acid Coursework
The discussion focuses on conducting chemical tests to identify an unknown acid, specifically MHSO4, where M is sodium or potassium. Two tests are highlighted: the emission of carbon dioxide in limewater and the reaction of the acid with a metal to produce hydrogen gas. The limewater test involves directing CO2 into limewater, resulting in a cloudy solution due to the formation of calcium carbonate. The second test requires a clean metal, such as zinc or copper, to observe bubble formation, indicating hydrogen gas release.
  • Understanding of acid-base reactions
  • Knowledge of gas evolution reactions
  • Familiarity with laboratory apparatus for gas collection
  • Basic chemistry concepts related to ions and their behavior
  • Research the properties and reactions of bisulfates like NaHSO4 and KHSO4
  • Learn about gas collection techniques in chemistry experiments
  • Study the principles of acid-base titration methods
  • Explore the role of H+ ions in acid-base chemistry
Chemistry students, laboratory technicians, and educators looking to understand practical methods for identifying acids and conducting chemical tests.
thick1
coursework - unknown acid: tests - PLEASE HELP!
can someone PLEASE help me?!
as my username suggests...i am thick when it comes to Chemistry...so i really need some help with my coursework.
basically i need to know the 2 chemical tests (without use of indicators) to test an unknown aqueous substance to see if it is an acid.
1 test is CO2 emission in Limewater.
2 test is H emission from acid + metal.
thing is...i don't know how you actually DO these tests...or anything about the H+ ions which cause the gas emissions.
PLEASE PLEASE PLEASE can someone help me out?
i need to know about the donating and receiving of H+ ions AND the apparatus needed and the methods of both the 2 tests.
Sorry...should have said...the unknown acid formula is MHSO4 (where M is either sodium or potassium).
Chemistry news on Phys.org
thick1 said:
1. Test is CO_2 emission in Limewater.
Simply heat whatever produces the carbond dioxide and then 'direct' the carbon dioxide into the limewater. The linewater will then turn cloudy because:
[tex]CO_2_{(g)} + Ca(OH)_2_{(l)} \rightarrow CaCO_3_{(s)} + H_2O_{(l)}[/tex]
Simple as that.
Search for a website and you should find the set up and the equation.
The Bob (2004 ©)
I don't see how the CO2 test in limewater help identify if an unknown liquid is an acid. What role does the unknown liquid play in this experiment ? Anyway, the reaction is what The Bob has described above and the carbonate (CaCO3) will form a milky white dispersion. This can be done by simply blowing the CO2 into the liquid using a transfer tube. In fact, as your breath has some CO2 in it, you can simply blow through a straw suberged in limewater to see it turn milky.
The second test makes sense. Take a fresh piece of metal, one without any oxide layer - preferably in the form or wire, wool, filings or ribbon, so as to provide a large surface area. Zinc ribbon or well-cleaned copper wire will do. Drop it into the unknown liquid and look for bubbles rising up from the piece of metal.
Establishing that the gas evolved is really hydrogen is a little harder and I don't know if that's required at your level.
Edit : Just noticed your last line which says that the unknown is (Na/K)HSO4. These are bisulphates, and though they contribute H+ ions, they are not strictly considered acids. Now I can definitely think of better tests to determine the unknown cation, but I'm not sure now, what exactly you're trying to identify - the unknown cation, or the acidity of the liquid.
  • · Replies 19 ·
11K
