| New Reply |
Special Relativity Clocks |
Share Thread | Thread Tools |
| Apr7-12, 11:25 AM | #35 |
George and DaleSpam,
Are we done here? The discussion here leads to the suggestion that the 'slow clock' idea, with τ<t, is only one possible result for the moving clocks. Choices of x other than x=vt lead to different relations, such as τ>t for x=0. Synchronization means that the result applies to all the moving clocks, including the one at the origin of the moving frame. Do you all accept this idea, or do we have some more to talk about? JM |
| Apr7-12, 01:18 PM | #36 |
Mentor
If you have a clock which is moving in an arbitrary fashion (including, but not limited to, x=vt) you use the following formula to calculate the time displayed on the clock: [tex]\tau = \int \sqrt{1-v(t)^2/c^2} dt[/tex] http://en.wikipedia.org/wiki/Proper_...ial_relativity The integrand is always less than or equal to 1, so you never get [itex]d\tau>dt[/itex] where t is the time coordinate in an inertial frame and v is the clock's velocity in that frame. |
| Apr7-12, 02:10 PM | #37 |
In any case, I explained what Einstein means in the part of my quote from post #28 that you left out: t is the time on a clock that was at rest in the stationary frame prior to t=0 and then at t=0 it instantly accelerates to velocity v and so becomes at rest in the frame moving at v where the transformed time is represented by τ. For any given time t in the stationary frame, you can calculate the time τ on a clock at the spatial origin of the moving frame using the simple formula τ=t√(1-v2/c2). After having developed the relationship between the time on a moving clock relative to the times on the stationary coordinate clocks, we extrapolate to the more general case of delta times so that we don't have to be restricted to the origin of a specific frame or even a specific speed and we can determine the instantaneous tick rate of an accelerating and moving clock compared to the coordinate time. But because √(1-v2/c2) can only be a number less than 1, we know that a moving clock will tick slower than the stationary coordinate clocks and that's why we say "slow clocks is a universal truth in Special Relativity". |
| Apr7-12, 02:29 PM | #38 |
Mentor
| Apr7-12, 03:21 PM | #39 |
| Apr13-12, 06:21 PM | #40 |
I have read your last replies. I dont understand clearly the reasoning of 1905 where he starts a clock from rest to develop the standard formula for 'slow clock'. Let me state in detail my reasoning. 1. Stay within SR, ie all moving clocks are stationary in the frame moving toward +x at speed v. 2.The transform equation relating the time τ of the moving frame to the coordinates x and t of the stationary frame is τ = ( t - vx/c[SUP]2[SUP])/√(1-v[SUP]2[SUP]/c2) 3. x and t are independent variables, ie they can take on any values both + and -. 4.For example let x=0.5ct (v/c = 0.8) in the equation to find τ =t. 5. Since the moving clocks are synchronized this result applies to all the moving clocks, including the one at the origin of the moving frame. 6. Therefore the moving clocks are not always slow. Comments?Is there a relation between the above and the section of 1905 on 'slow clocks'? JM |
| Apr13-12, 07:17 PM | #41 |
| Apr13-12, 08:31 PM | #42 |
![]() to the first part of this: ![]() and he did it by replacing x with vt but remember, there is more to the Lorentz Transformation than just the formula for τ. There are also the formulas for the spatial co-ordinates and if we plug x=vt into x'=γ(x-vt) we get: x'=γ(vt-vt)=0 So this tells us that it is not all the clocks in the moving frame that the time co-ordinate applies to but only the one at the spatial origin of the moving frame which is where the moving clock that we are considering is located. Now, concerning 3, x and t are not independent of each other in this situation, they are related by x=vt, as you pointed out in your post #26. Concerning 4, I can't tell what you are doing, can you provide more detailed steps? Points 5 and 6 were covered in my earlier comments. |
| Apr13-12, 09:22 PM | #43 |
Mentor
| Apr13-12, 10:09 PM | #44 |
in the Homework Intro Physics section (page one) see update With the evaluation of the above integral and it was not a good answer since the recorded proper time of the (constant) accelerating clock ( with respect to earth clock ) was greater than earth clock ? So I have questions on that integral. Once again , discussing proper time is confusing , so numerical problems might help |
| Apr14-12, 06:24 AM | #45 |
Mentor
I checked your math, and it seems all right, but your answer was wrong. I don't know if you accidentally plugged it in to the integrator wrong or if the integrator had some numerical problems.
| Apr14-12, 02:02 PM | #46 |
t' = ( t - vx)/√(1-v2) where I am using units such that c=1 to make things more manageable. t' = ( t - vx)/√(1-v2) t' = ( 0 - 0.8*0.5)/√(1-0.82) t' = ( 0 - 0.4)/0.6 = -0.66666 seconds. t' = ( t - vx)/√(1-v2) t' = ( 0 - 0.8*0)/√(1-0.82) t' = ( 0 - 0)/0.6 = 0 seconds. There is a difference of -0.6666 seconds between the times of the clocks at rest in S' when the clocks at rest in S are all reading 0 according to the observers at rest in S. The equations shown so far only concern coordinate times that label events and says nothing about the relative rates at which clocks with relative motion run. To obtain the elapsed time (t2-t1) in frame S, between two events when the elapsed time interval between those two events in frame S' is (t2'-t1') we use: [itex] t2-t1 = \Delta t = ( t2' + v*x2')/\sqrt{1-v^2} - (t1' + v*x1')/\sqrt{1-v^2} [/itex] [itex] \Delta t = (\Delta t' + v*x2' - v*x1')/\sqrt{1-v^2} [/itex] [itex] \Delta t = (\Delta t' + v* \Delta x')/\sqrt{1-v^2} [/itex] Since we after the proper time in the primed frame we only use a single clock at rest in that reference frame, so x2' must equal x1' so we can say: [itex] \Delta t = \Delta t' /\sqrt{1-v^2} [/itex] [itex] \Delta t' = \Delta t * \sqrt{1-v^2} [/itex] [itex] \Delta \tau = \Delta t * \sqrt{1-v^2} [/itex] Now using the above equation can you find a single instance when [itex] \Delta \tau > \Delta t * \sqrt{1-v^2} [/itex]? Maybe what you are getting at is that the coordinate time interval as measured in S' between between two events may be longer than the coordinate interval between those two events as measured in S? For example using: [itex] \Delta t' = \Delta t *\sqrt{1-v^2} - v* \Delta x' [/itex] [itex] \Delta t'[/itex] can be greater than [itex] \Delta t [/itex] if [itex] \Delta x' [/itex] is negative, but this does not mean individual clocks in S' are running faster than individual clocks in S according to observers at rest in S. It is simply a result of how clocks are synchronised and the relativity of simultaneity (What appears simultaneous in one rest frame is not simultaneous in another reference frame with relative motion). |
| Apr14-12, 02:55 PM | #47 |
Mentor
| Apr15-12, 07:47 AM | #49 |
Mentor
| Apr15-12, 09:32 AM | #50 |
Even if he specified a duration of 1 in S, the location of the moving clock is not necessarily 0.8 if the clock did not start at the origin, (which he did not specify). If he had made it clear that he meant [itex]\Delta x = 0.5[/itex] when [itex]\Delta t = 1.0[/itex] then there would be a contradiction when v=0.8, but he did not specify a time interval or a starting coordinate or that he talking about intervals (differences) rather than coordinates of individual events. Perhaps you mean that the single statement: |
| Apr15-12, 09:37 AM | #51 |
[QUOTE=DaleSpam;3854185]No, I don't accept the idea.
If you have a clock which is moving in an arbitrary fashion (including, but not limited to, x=vt) you use the following formula to calculate the time displayed on the clock: [tex]\tau = \int \sqrt{1-v(t)^2/c^2} dt[/tex] [\QUOTE] Dale--I see where this formula comes from, and I think it is a valid result. The question is whether it is a 'universal' result, ie 'moving clocks always run slow, meaning t (moving) <T(stationary)'. Lets use x,y,z,t = moving coordinates and X,Y,Z,T =stationary coordinates. Either X and T are independent coordinates and some values of X lead to t ≥ T, or X is restricted to X=vT and t is always < T. The two appear to be mutually exclusive. The 1905 paper is careful and rigorous in section 3 where the Lorentz transforms are derived and uses those transforms in Part 2 to analyze the Maxwell equations. But section 4 is vague and puzzling ( I have heard many interpretatons of what Einstein meant) and the results are not used elsewhere. So I prefer that 'slow clocks' is only one example, but not universal. I am hoping to get a clear answer from this discussion. JM |
| New Reply |
| Thread Tools | |
Similar Threads for: Special Relativity Clocks
| Special Relativity Clocks | Special & General Relativity | 90 | ||
| special relativity clocks observed from two frames | Introductory Physics Homework | 3 | ||
| theory of special relativity -clocks and objects | Introductory Physics Homework | 1 | ||
| Clocks out of Sync (Special Relativity) | Introductory Physics Homework | 7 | ||
| synchronized clocks in special relativity | Special & General Relativity | 17 | ||
