| New Reply |
Special Relativity Clocks |
Share Thread |
| May18-12, 08:53 PM | #120 |
Special Relativity ClocksJM |
| May18-12, 09:18 PM | #121 |
I know this is an early post, but it seems relavent now.
JM |
| May18-12, 09:56 PM | #122 |
Mentor
| May18-12, 10:10 PM | #123 |
It is not apparent to me. If it is to you,can you explain it to me? Where are the points A and B in terms of x,y,z,t, and where is the polygonal line? The theory of section 3 refers to clocks moving parallel to x, so how to make a polygon out of that? The picture that sentence suggests to me is a series of stationary frames, each one aligned along one segment of the polygonal line, with an accompanying moving frame. The change of direction from one segment to another implies an acceleration of the clock. I don't see anything in section 3 about that. If one clock is on the equator and the other is at the pole then their positions will never coincide. So what is the explanation? Thanks again for your efforts. JM |
| May19-12, 05:47 AM | #124 |
So once Einstein establishes that any clock that moves in a reference frame along the x-axis will tick at a slower rate than the co-ordinate clocks of that reference frame, he generalizes the concept to include any clock moving in any direction and he says to pick any two additional clocks, one at any point A and one at any other point B, not necessarily aligned along the x-axis, which had previously been synchronized with each other when at relative rest, and move the one at A to the position of the one at B at some relatively slow velocity v, then when it gets there, it will be slow by ˝tv2/c2 compared to the clock at B. (Note that this formula is approximate and only applies to a slow-moving clock.) Then he says that we can repeat the process, moving the A clock from the first B position to another B position in any other direction and we will get the same additional difference in clock time when it gets there. We can repeat the process as many times and in as many directions as we want, even to the point where we eventually return the A clock to its original location and the same formula applies if we take the total time t for the clock to make its round trip. This is what he means by the A and B points coinciding. Don't be confused by the oft-repeated statement that clocks have to be co-located at the start and end of the journey of one of them to compare times. All frames will show that there is a difference in accumulated times, even if they don't agree on the absolute times on the two clocks (because of simultaneity issues). But the point is that no one makes a clock that is designed to tick slowly when it is traveling with respect to some rest frame--how in the world would they do that? And you overlook that fact that two identical clocks in inertial relative motion would each tick more slowly compared to its own tick rate. How do you design clocks to do that? No, it happens independently of any purposeful design, in fact if you tried to make it happen, it wouldn't be reciprocal. Now if you look at the end of chapter 12, you will see this statement: |
| May19-12, 07:51 AM | #125 |
Mentor
What is a coordinate clock? That is also a non standard term. Is it defined somewhere or are you just making things up? |
| May19-12, 08:27 AM | #126 |
Length = √( x2+y2+z2) But worldlines are 4-dimensional and the proper length is given by the Lorentzian length, L = √( c2t2-x2-y2-z2) or T = √( t2-x2/c2-y2/c2-z2/c2) with this definition of length, the strings length depends on its shape. A twisty bent piece of string is shorter than it would be if measured stretched out. This is why the travelling twin is younger than the stay at home twin http://en.wikipedia.org/wiki/Proper_time |
| May24-12, 07:43 AM | #127 |
I am still puzzled by your, and DaleSpams, reluctance to identify published sources for your ideas. Surely there must be some, what gives? The responses to my posts suggest that there is a line of theory that is not wholly included in Einsteins works. I have heard of world lines, maybe in French, and Taylor hints at a different viewpoint. Us old timers prefer paper books to internet, maybe because of editing and reviewing. I can see that you have put much effort into this conversation, and I appreciate it. JM |
| May24-12, 07:55 AM | #128 |
[/QUOTE]http://en.wikipedia.org/wiki/Proper_time[/QUOTE] Thanks for the reference, I'll look into it. JM |
| May24-12, 09:12 AM | #129 |
Mentor
Once you understand the Wikipedia page then you can search for "spacetime interval" or "line element" or "spacetime metric" or "Riemannian metric" for more information, but most of that will be too advanced until you have mastered the material on the Wikipedia page. If you specifically want paper-published sources then any introductory SR textbook will include material on proper time although it may be called "spacetime interval", or "invariant interval". You have some textbooks already, just start in the index there if you don't like Wikipedia. |
| May24-12, 09:16 AM | #130 |
Mentor
| May24-12, 10:17 AM | #131 |
We can't ignore the issue of moving clocks ticking at different rates and rather than saying it is all meaningless, we have agreed upon conventions to make the best sense out of the situation. |
| May24-12, 10:36 AM | #132 |
If an inertial clock can be present at the two events, then the spacetime interval is "timelike" and is the accumulated time on the clock. This is Taylor and Wheeler's definition of a "proper clock". There is an inertial frame in which the clock is at rest. If the two events are so far apart that a physical clock could not get from the first event to the second event, then the spacetime interval is "spacelike" and is measured with an inertial ruler spanning between the two events and in a frame in which it is at rest. Taylor and Wheeler did not call this a "proper ruler" but they could have. Since light rays don't have rest frames, the concept of a spacetime interval is meaningless for events that a light ray is present at both of them. |
| May24-12, 12:06 PM | #133 |
| Jun2-12, 10:58 AM | #134 |
So, can you recommend a specific ' introductory SR textbook' , or not? JM |
| Jun2-12, 11:43 AM | #135 |
I still don't see the principles or math that justify the generalization from clocks moving along x to clocks moving in arbitrary directions. At one point you seemed to say that all clocks (did you mean both moving and stationary?)tick at the same rate, ie one tick per second. I cited reasons to believe this. Then, above, you say that moving clocks tick at a different rate. So, which is it? So you don't read Minkowski, don't like Taylor, and don't have a suggested text. Then where do you get your ideas about SR? JM |
| Jun2-12, 12:19 PM | #136 |
Mentor
http://arxiv.org/abs/gr-qc/9712019 Chapter 1 is just SR, and he introduces the spacetime interval on page 3 and makes the connection to proper time on page 26. |
| New Reply |
Similar discussions for: Special Relativity Clocks
| Special Relativity Clocks | Special & General Relativity | 90 | ||
| special relativity clocks observed from two frames | Introductory Physics Homework | 3 | ||
| theory of special relativity -clocks and objects | Introductory Physics Homework | 1 | ||
| Clocks out of Sync (Special Relativity) | Introductory Physics Homework | 7 | ||
| synchronized clocks in special relativity | Special & General Relativity | 17 | ||
