Calculating Net Electric Field at Origin: Two Charges on X-Axis, Two on Y-Axis
The problem involves calculating the net electric field at the origin due to four charges positioned on the x and y axes. The charges include two positive charges on the x-axis and one positive and one negative charge on the y-axis.
  • The original poster attempts to apply the formula for electric field strength, questioning the cancellation of charges and the relevance of the charge at the origin.
  • Some participants suggest using the formula for the electric field created by a point charge and applying it for each charge separately before summing the vectors.
  • There is a recurring uncertainty about the role of the charge at the origin in the calculations.
The discussion is ongoing, with participants exploring different aspects of the electric field calculations. Some guidance has been provided regarding the application of the electric field formula, but there is no explicit consensus on the approach to take.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is also a noted confusion regarding the cancellation of charges and the interpretation of the charge at the origin.
thursdaytbs
Electric Field question:
Two charges are located on the x axis: q1 = +6.0 micro-Coloumbs at x1=+4cm, and q2=+6 micro-coloumbs at x2 = -4cm. Two other charges are located on the y-axis: q3 = +3 micro-Coloumbs at y3=+5cm, and q4 = -8 micro coloumbs at y4 = +7cm. Find the net electric field (magnitude and direction) at the origin.
What I've tried to do is say E = F/q, and F = Kq1q2 / r^2, therefore E = (kq1q2 / r^2) / q. since q2 = origin, it = 1? and the q1 and q cancel out? So it becomes: E=k/r^2?
I'm pretty sure I'm doing it wrong and was wondering if someone could just point me in the right direction?
Any help appreciaited, thanks. :smile:
HINT:The electric (electrostatic) field created by a charge 'q' at the point [itex]\vec{r}[/itex] is given by
[tex]\vec{E}_{q,\vec{r}}=:\frac{q}{4\pi\epsilon_{0}r^{2}}\frac{\vec{r}}{r}[/tex]
,where [itex]\vec{r}[/itex] is the position vector at the point u wish to calculate the fiels wrt to the point in which is the source "q".
Daniel.
PS.You'll have to apply that formula 4 times (for each charge) and then add those 4 vectors obtained.
E = F/q(o) where q(o) is the charge experiencing the force.
so E = Kq1q(o)/(r^2*q(o)) <----q1 is the charge providing the force and the q(o) is the charge that would be at the origin. However though, as you mentioned before, it does cancel out.
Thanks for the help everyone.
  • · Replies 16 ·
