New Reply
gears design for a screw jack
Share Thread Thread Tools
Mar19-12, 09:19 AM   #1
i have to design gears for a screw jack. i have initial rpm 1500 and final rpm 100. my gear at the point of the power screw is 0.04 m and i want to calculate the diameter for the other 3 gears. can you please help me thank you
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Mar19-12, 07:15 PM   #2
Sketch up the gear train you need to build, with gear tooth numbers n1, n2, n3, n4 and then write down the equation for the train ratio. Look at your given information to see what the train ratio has to be, and then start making some reasonable estimates for tooth numbers.
No pinion should have less than 12 teeth to avoid under cutting when the tooth is being formed. Typically you do not want to go to tooth numbers a whole lot more than 100 as they are more expensive to make.
New Reply
Thread Tools
Similar Threads for: gears design for a screw jack
Thread Forum Replies
Screw design needed Mechanical Engineering 4
a basic question from screw jack coefficient of friction Classical Physics 1
coefficient of friction of screw jack in lowering case.. Engineering, Comp Sci, & Technology Homework 0
HELP! Howto design power screw drive Mechanical Engineering 8
