| New Reply |
Multiple Pulleys and Masses with Friction |
Share Thread | Thread Tools |
| Mar19-12, 03:12 PM | #1 |
![]() I have solved the question but I am still iffy as to whether my solution is correct or not. 2. Relevant equations Let m1 = 10kg. Let m2 = 20kg. (1) m1a1 = T1 - μm1g (2) m2aa = m2g - T2 (3) 2T1 = T2 (4) 2a2 = a1 3. The attempt at a solution T2 = m2g T2 = (20kg)(9.8m/s2) T2 = 196N T1 = [itex]\frac{T_{2} + μm_{1}g}{2}[/itex] T1 = [itex]\frac{196N + (0.32)(10kg)(9.8m/s^{2})}{2}[/itex] T1 = 113.68N Sub (3) and (4) into (2) m2a2 = m2g - T2 m2([itex]\frac{a_{1}}{2}[/itex]) = m2g - 2T1 Called this new equation (5). (5) m2([itex]\frac{a_{1}}{2}[/itex]) = m2g - 2T1 (1) m1a1 = T1 - μm1g (5) m2([itex]\frac{a_{1}}{2}[/itex]) = m2g - 2T1 (1) + (5) m1a1 + m2([itex]\frac{a_{1}}{2}[/itex]) = T1 - μm1g + m2g - 2T1 a1(m1 + m2([itex]\frac{1}{2}[/itex]) = -μm1g + m2g - T1 a1(10kg + 20kg([itex]\frac{1}{2}[/itex]) = -(0.32)(10kg)(9.8m/s2)+(20kg)(9.8m/s2)-113.68N a1 = 2.5448 m/s2 from (4) 2a2 = a1 a2 = [itex]\frac{a_{1}}{2}[/itex] a2 = [itex]\frac{2.548m/s^{2}}{2}[/itex] a2 = 1.274 m/s2 Therefore, T1 = 113.68N, T2 = 196N, a1 = 2.548 m/s2, and a2 = 1.274 m/s2. My question is if my solution is correct. Please check and reply back with suggestions or corrections. Thank you so much. |
| Mar19-12, 07:53 PM | #2 |
Please help me with this question. have i done this question correctly?
| New Reply |
| Tags |
| acceleration, force of friction, tension, two mass, two pulleys |
| Thread Tools | |
Similar Threads for: Multiple Pulleys and Masses with Friction
| Pulleys with masses | Introductory Physics Homework | 8 | ||
| Kinetic friction, tension, multiple masses | Introductory Physics Homework | 15 | ||
| 4 Pulleys, 2 Masses | Introductory Physics Homework | 3 | ||
| Masses and pulleys?! | Introductory Physics Homework | 2 | ||
