| New Reply |
San Onofre steam generator tubes leaking - why? |
Share Thread | Thread Tools |
| Mar24-12, 10:16 AM | #18 |
San Onofre steam generator tubes leaking - why?Rotor dynamics is fascinating. I suppose it's quite a calculation to get the natural frequency and vibration modes of a long hollow tube that's pressurized with the fluid inside having considerable velocity. When i read how a Coriolis Flowmeter works , i just felt like saluting the entire Mechanical Engineering community. http://en.wikipedia.org/wiki/Mass_fl...lis_flow_meter it somewhat resembles the u-tubes in steam generator, see this graphic http://en.wikipedia.org/wiki/File:Co...ow_512x512.gif I'm admitting my abysmal ignorance here. I know just enough to not cast stones, and that wasn't intent of previous post... |
| Mar27-12, 07:25 PM | #19 |
Admin
CONFIRMATORY ACTION LETTER – SAN ONOFRE NUCLEAR GENERATING STATION, UNITS 2 AND 3, COMMITMENTS TO ADDRESS STEAM GENERATOR TUBE DEGRADATION |
| Apr2-12, 12:12 PM | #20 |
Story on San Onofre Steam Generator Leakage.
http://www.power-eng.com/news/2012/0...-troubles.html Story above is based on Arnie Gunderson Report prepared for the Friends of the Earth environmental and anti-nuclear group. http://fairewinds.com/content/foe-re...res-san-onofre Biggest error is that the quote from NRC chairman Jaczco that NRC approval is not required for restart is not current. The Confirmatory Action Letter issued to SCE requires NRC approval. I am still looking for a copy of the CAL itself. I haven’t found it on ADAMS yet. I do like the list of changes implemented in the new steam generators. Arnie is correct that the increased number of tubes, change in tube alloy, changes in tube support structure (egg crate - implying fragility???) and increased coolant flow are potential causes. I think pulling in the issue of BWR Dryer Cracking is a stretch though. Anyway this is a potential for a good discussion here on PF. |
| Apr2-12, 01:27 PM | #21 |
Admin
The CAL is in my previous post.
I don't think switching to 690 from 600 (?) is an issue, as that is the industry practice over the last two decades. Smaller tubes and increased flow rates might play a role, but I'd have expected a CFD analysis would have caught that - but maybe not if not done right. BWR dryer is different material in a different environment over a longer period. That's mixing apples with oranges, but it is an interesting topic nevertheless. |
| Apr2-12, 01:53 PM | #22 |
You expressed interest in the divider plate defect in the rplacement S/G for unit 3. Here are the references I found. (I am not a weld engineer and won't even try to comment.) IN 2010-07 http://pbadupws.nrc.gov/docs/ML1000/ML100070106.pdf Slide Presentation on root cause: http://pbadupws.nrc.gov/docs/ML0925/ML092590470.pdf Non Proprietary Root Cause Report: http://pbadupws.nrc.gov/docs/ML0926/ML092600513.pdf http://pbadupws.nrc.gov/docs/ML0926/ML092600515.pdf http://pbadupws.nrc.gov/docs/ML0926/ML092600516.pdf |
| Apr2-12, 02:49 PM | #23 |
Admin
Somewhat relevant - Effects of Alloy Chemistry, Cold Work, and Water Chemistry on Corrosion Fatigue and Stress Corrosion Cracking of Nickel Alloys and Welds
http://www.nrc.gov/reading-rm/doc-co...721/cr6721.pdf They process used low carbon Alloy 152 in butter welds as expected. They used gouging to remove the SS cladding in Unit 3 RSGs rather than the machining used in Unit 2 RSGs. |
| Apr16-12, 09:27 AM | #24 |
I came across this news article that may be of interest.
It sounds as though anti-vibration supports were removed to increase the number of tubes in the generator. This has led to more vibration and mechanical wear as a result. |
| Apr16-12, 03:38 PM | #25 |
| Apr16-12, 03:54 PM | #26 |
You're absolutely right. From the article:
| Apr18-12, 07:13 PM | #27 |
http://www.nrc.gov/reading-rm/doc-co...0120416en.html Part 21 Event Number: 47833 Rep Org: MITSUBISHI NUCLEAR ENERGY SYSTEMS Licensee: MITSUBISHI HEAVY INDUSTRIES, LTD Region: 1 City: ARLINGTON State: VA County: License #: Agreement: Y Docket: NRC Notified By: EI KADOKAMI HQ OPS Officer: JOHN KNOKE Notification Date: 04/13/2012 Notification Time: 15:58 [ET] Event Date: 04/13/2012 Event Time: [EDT] Last Update Date: 04/16/2012 Emergency Class: NON EMERGENCY 10 CFR Section: 21.21(a)(2) - INTERIM EVAL OF DEVIATION Person (Organization): BLAKE WELLING (R1DO) KATHLEEN O'DONOHUE (R2DO) DAVID HILLS (R3DO) VINCENT GADDY (R4DO) PART 21 GROUP (EMAI) Event Text PART 21 INTERIM REPORT - STEAM GENERATOR TUBE WEAR This interim Part 21 is in regard to San Onofre Nuclear Generating Station, Unit 2, Steam Generator replacement. "During the first refueling outage following steam generator replacement, eddy current testing identified ten total tubes with depths of 90 to 28 percent of the tube wall thickness. Some of the affected tubes were located adjacent to retainer bars. The retainer bars are part of the floating anti-vibration bar (AVB) structure that stabilizes the u-bend region of the tubes. "Other tubes in the two steam generators had detectable wear associated with support points elsewhere in the AVB structure. Each steam generator has 9727 tubes with an 8 percent (778 tubes) design margin for tube plugging. "Discovery Date: February 13, 2012 "Evaluation completion schedule date: May 31, 2012" "Those Mitsubishi Heavy Industries customers potentially affected by this issue have been notified and will receive a copy of this interim report." Reference Document: UET-20120089 Interim Report No: U21-018-IR (0) |
| May9-12, 11:22 AM | #28 |
Admin
| May9-12, 01:15 PM | #29 |
| May10-12, 12:41 AM | #30 |
i'm sure curious why the new tubes fail .
Flow inside those tubes barely changes with power. Seems to me a microphone on the steam generator could hear tubes clattering. I'd instrument a steam generator and listen. If they clatter at zero power then excitation is from primary flow not secondary. Most plants have loose parts monitors that are basically microphones at natural collection points like reactor vessel bottom and steam generator inlet side tubesheet. Move one up to vicinity of the tube wear region. old jim |
| May10-12, 09:32 AM | #31 |
Admin
Flow might have increased because of the reduced pressure drop, and perhaps flow was increased slightly, on the primary and/or secondary side in order to increase power output. Increased flow in the primary circuit always an issue when replacing steam generators. I'm puzzled about what kind of analysis was performed concerning the design. In this day and age, we have pretty advanced CFD capability. I'm left wondering - what did they miss, or not consider, in the design and the analysis. |
| May10-12, 12:07 PM | #32 |
http://en.wikipedia.org/wiki/List_of...nts_of_inertia (Pardon me i'm no mechanical engineer) so reducing diameter will reduce stiffness ? Surely they calculated that. The tubes get additional stiffness due to internal-external Δp and i dont know how to calculate that. That Δp is not constant as main steam pressure changes from ~ 1000 psi to ~ 800 with power. As you said surely they couldn't have missed that. It gets curioser and curioser. They'll figure it out. They have my genuine sympathy . old jim |
| May10-12, 01:11 PM | #33 |
Installing such acoustic monitors might have been possible as part of the RSG startup, but I don't think they will be heating the unit up / running the RCPs just so they can listen in and try to identify the problem. Too late for that. They will have to figure it out with inspections, whatever operating data is available now, and some fancy analysis.
| Jul20-12, 11:35 AM | #34 |
Admin
Vendor singled out by SONGS findings
http://www.world-nuclear-news.org/RS...s_200712a.html Nevertheless - the licensee is responsible for oversight and quality of whatever component or system is installed in the plant. |
| New Reply |
| Thread Tools | |
Similar Threads for: San Onofre steam generator tubes leaking - why?
| Steam Generator problem | Engineering, Comp Sci, & Technology Homework | 3 | ||
| Steam power generator | Engineering Systems & Design | 10 | ||
| Steam Generator take me off grid. | Mechanical Engineering | 10 | ||
| biomass steam generator | Engineering Systems & Design | 2 | ||
