Register to reply
Find the hydrostatic force on one end of the tank if it is filled to a depth of 8 ft.
by sushifan
Tags: force distance
Share this thread:
sushifan
#1
Mar23-12, 03:45 PM
P: 27
A large tank is designed with ends in the shape of the region between the curves y =(1/2)x^2 and y = 12, measured in feet. Find the hydrostatic force on one end of the tank if it is filled to a depth of 8 ft with gasoline. (Assume the gasoline's density is 42.0 lb/ft^3).
This is a section on applications.
2. Relevant equations
I'm not sure if this is precisely all I need.
Force F = ρgdA (g gravity, d depth, A area)
3. The attempt at a solution
(42.0)(9.8) ∫ sqrt(2y) (8-y) dy on [0,8]
823.2 ∫ 8 sqrt(2y) - ysqrt(2y) dy on [0,8]
823.2 [ 16sqrt(2)/3 y^(3/2) - 2sqrt(2)/5 y^(5/2)] on [0,8]
which evaluates to 56, 197.12 lb
I always get scared when I deal with word problems and end up with such large answers.
Phys.Org News Partner Science news on Phys.org
An interesting glimpse into how future state-of-the-art electronics might work
Tissue regeneration using anti-inflammatory nanomolecules
C2D2 fighting corrosion
tiny-tim
#2
Mar24-12, 04:40 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
hi sushifan!
Quote Quote by sushifan View Post
yes, that looks ok , except
i] you've only included half the tank (the x > 0 side)
ii] erm feet, lbs, 9.8 ?
iii] i'm not familiar with these units, but i wonder, do you need g at all if you're using lbs ?
Register to reply
Related Discussions
Hydrostatic Equation/Finding depth Introductory Physics Homework 7
Calculating the Hydrostatic Force on the wall of a Cylindrical Tank Classical Physics 3
Hydrostatic pressure -tank Mechanical Engineering 6
Find the hydrostatic force exerted on a sphere Advanced Physics Homework 4
Find the depth of a tube submerged in water that is half filled with air Introductory Physics Homework 9
