| New Reply |
understanding bell's theorem: why hidden variables imply a linear relationship? |
Share Thread | Thread Tools |
| Mar30-12, 09:22 PM | #52 |
understanding bell's theorem: why hidden variables imply a linear relationship?What I would agree with is that the practical design and execution of Bell tests is irrelevant to the question of whether, in principle, LR models of entanglement can be compatible with all the predictions of QM. It's been definitively shown, imo, that any LR model of entanglement following Bell's formal treatment is, in principle, incompatible with QM. If you want to show that the assumption that our universe is evolving deterministically in accordance with the principle of locality is incompatible with, say, Herbert's proof, then you'll have to do more than just reiterate or elaborate on the proofs of Bell, Herbert, et al. or refer to the experimental violation of BIs. You'll have to show exactly why experimental BI violations can't possibly be due to anything other than either instantaneous action at a distance or ftl transmissions. And to do that you're going to have to, among other things, refer to the precise relationship between LR models of entanglement and the design and execution of Bell tests. |
| Mar30-12, 10:32 PM | #53 |
If the polarizers are 0 degrees apart 100 pairs will give the same result. If the polarizers are 30 degrees apart, 75 pairs will give the same result. If the polarizers are 45 degrees apart, 50 pairs will give the same result. If the polarizers are 60 degrees apart, 25 pairs will give the same result. If the polarizers are 90 degrees apart, 0 pairs will give the same result. In general, if the polarizers are an angle θ apart, the number of pairs that give the same result is 100cos2(θ) and the number of pairs that give different results is 100sin2(θ). If x=y and y=z, then x=z, agreed? Thus if x≠z, then either x≠y or y≠z, agreed? (What we really mean is x≠y or y≠z or both, but in mathematics it's customary to use the word "or" to mean "A or B or both.) But by the laws of probability, the probability that x≠y or y≠z is less than or equal to the probability that x≠y plus the probability that y≠z. Thus the probability that x≠z is less than or equal to the probability that x≠y plus the probability that y≠z. Does that make sense to you? In our case, x is "the instruction at -30", y is "the instruction at 0", and z is "the instruction at 30". |
| Mar31-12, 03:12 PM | #54 |
| Mar31-12, 03:15 PM | #55 |
| Mar31-12, 08:27 PM | #56 |
| Mar31-12, 10:44 PM | #57 |
can you put the above numbers for un-entangled photons? i guess it would be 33 pairs would give same result... i assume that the probabilities would be unaffected by the polarizer angles, in case of un-entangled photons, is that correct? |
| Apr1-12, 12:58 AM | #58 |
Per QM/actual experiment - At (-30,30) the mismatch is 75 pairs at (-30,0) the mismatch is 25 pairs at (0,30) the mismatch is 25 pairs Mr. bell is saying that per LHV the result (at the most) should be 50 not 75 using additive law of probability. The extra 25 is due to entanglement. is the above logic correct? |
| Apr1-12, 11:58 AM | #59 |
| Apr1-12, 12:04 PM | #60 |
the short answer is: the hidden variables imply a linear relationship because the laws of probability are additive?...and not cosine, exponential etc you might want to check out...... http://physicsforums.com/showthread.php?t=592401 |
| Apr1-12, 01:04 PM | #61 |
For a simple example of this, consider the case when you turn both polarizers to the same angle. Then, as you know, they'll either both go through or they'll both not go through. They have a 50 percent chance of both going through and a 50 percent chance of both not goon through. Of course, if you just looked at one of the polarizers it will just seem like the photon is just randomly going through or not going through. But if the experimenters recording the results of the two polarizers compare their data, they will find a remarkable phenomenon: the two photons always do the same thing! |
| Apr1-12, 01:13 PM | #62 |
| Apr1-12, 01:16 PM | #63 |
this happens often with people....they come up with some way to do faster than light communication and then forgot they missed the fact that....both the "ends" need to be compared.....:) |
| Apr1-12, 08:07 PM | #65 |
provided there used as an awareness of what may or may not be and not the be all .there how we built the world
| Apr1-12, 11:48 PM | #66 |
Maybe if you put your argument in a form like: 'If the universe is local deterministic, then ___ must be the case ...', and so on. |
| Apr1-12, 11:55 PM | #67 |
| Apr2-12, 12:24 AM | #68 |
1. Entangled photons behave identically at identical polarizer settings. 2. In a local deterministic universe, the polarizer angles the photons will and won't go through must be agreed upon in advance by the two entangled photons. 3. In order for the agreed-upon instructions (to go through or not go through) at -30 and 30 to be different, either the instructions at -30 and 0 are different or the instructions at 0 and 30 are different. 4. The probability for the instructions at -30 and 30 to be different is less than or equal to the probability for the instruction at -30 and 0 to be different plus the probability for the instructions at 0 and 30 to be different. |
| New Reply |
| Thread Tools | |
Similar Threads for: understanding bell's theorem: why hidden variables imply a linear relationship?
| Hidden variables | Advanced Physics Homework | 0 | ||
| Hidden variables, Bell's theorem, etc | Quantum Physics | 5 | ||
| Hidden Variables | Quantum Physics | 9 | ||
| relationship between Linear and Rotational Variables | General Physics | 6 | ||
| QM hidden variables | Quantum Physics | 46 | ||
