| New Reply |
understanding bell's theorem: why hidden variables imply a linear relationship? |
Share Thread | Thread Tools |
| Apr2-12, 12:31 AM | #69 |
| Apr2-12, 02:14 AM | #70 |
LR models of entanglement have two main features: 1) functions determining rate of individual detection are constructed based on the assumption that a detectable transmission by a polarizer is due to a value of a variable parameter of an underlying property of an incident disturbance interacting with a polarizer setting, and 2) a function determining rate of coincidental detection is constructed based on the assumptions of, i) the independence of events/interactions at the distantly separated polarizers, and ii) a probability distribution of the hidden variable (entailing, ie., that coincidental detection is determined, in the formalism, by the hidden variable that determines individual detection). 1) is compatible with QM and experiment, 2i) isn't. If perfect, loophole-free Bell tests were ever done, then would QM would suddenly become incorrect? Would QM suddenly become compatible with LR? If not, then you'd have the same situation that exists now with QM making some reasonable assumptions regarding detection and pairing efficiencies. I'll go through your 4 steps, step by step, in my next post. |
| Apr2-12, 03:48 AM | #71 |
As I now understand it (I'm still very much learning here!), hidden variables may imply a linear relationship for some hypothetical experiments, but do not necessarily imply a linear relationship for realistic experiments as performed until today. |
| Apr2-12, 03:53 AM | #72 |
| Apr2-12, 04:32 AM | #73 |
[QUOTE=San K;3842509]Agreed. [local hidden variables says that the polarizer angles the photons will and won't go through are agreed upon in advance]
I disagree: that sounds like determinism without any allowance for "randomness". However, that isn't how most people think that nature works, has nothing to do with realism, and as Bell admitted, was also not required by EPR. |
| Apr2-12, 04:59 AM | #74 |
| Apr2-12, 05:36 AM | #75 |
Before we nitpick your 4 steps, I'd like to address some other statements you made.
As for the assumption of a fundamental deterministic evolution. It's, in principle, nontestable. It's an unfalsifiable assumption. Just as the assumption of a fundamental nondeterminism is. From step 1. we might assume that the value of λ, the variable determining whether a photon will go through a polarizer or not, is the same for photons 1 and 2 of any given pair when θ = 0° . If the value of λ is the same for photons 1 and 2 of an entangled pair when θ = 0°, then is there any reason to suppose that λ would be different for photons 1 and 2 of an entangled pair wrt any other θ, such as 30°? Before we deal with that, we might speculate about the nature of λ in these experiments involving light and polarizers. The intensity of the light they transmit is affected by the polarizer's orientation. In a polariscopic setup, the intensity of the light transmitted by the analyzing polarizer varies as cos2θ. If we think of the optical disturbances incident on the polarizers as rotating wave shells whose expansion is constrained and directed by the transmission lines, then we can visualize the relationship between the polarizer setting and the axis of rotation as determining the amplitude of the wavefront filtered by the polarizer. So, for our purposes, the assumption that the rotational axes of entangled photons is identical seems to fit with the experimental result noted in step 1. This common rotational axis of entangled photons, represented by λ, is also compatible with the assumption that it's produced locally via a common emission source. Back to the preceding question. If photons 1 and 2 of any entangled pair have the exact same rotational axis, then how would we expect the rate of coincidental detection to vary as θ varies? Using another QM observation we note that rate of individual detection doesn't vary with polarizer orientation, so we assume that λ is varying randomly from entangled pair to entangled pair. We also note that rate of coincidental detection only varies with θ, and, most importantly, as cos2θ. Is this behavior compatible with our conceptualization of λ? It seems to be. Start with a source emitting entangled photons with λ varying randomly. The emitter is flanked by two detectors A and B. Whatever the rate of coincidental detection is in this setup is normalized to 1. After putting identical polarizers in place, one between the emitter and A and one between the emitter and B, we note that the maximum rate of coincidental detection is .5 what it was without the polarizers, and that it varies from .5, at θ = 0° to 0 at θ = 90° as cos2θ. Now visualize this setup without the emitter in the middle and with the polarizers aligned (θ = 0°). We note a common rotational axis extending between the polarizers. Now rotate one or both of the polarizers to create a θ of 30°. We note a common rotational axis extending between the polarizers. Now rotate one or both of the polarizers to create a θ of 60°. We note a common rotational axis extending between the polarizers. It's just like a polariscope, except that the source emitting random λ's is in the middle rather than at one end or the other, so both polarizers are analyzers, and the rate of coincidental detection is a function of the same angular dependency, and analogous to the detected intensity, as in a regular polariscopic setup. Thus, the nonlinear angular dependencies observed in Bell tests are intuitive, and compatible with a local deterministic view. |
| Apr2-12, 11:20 AM | #76 |
also this is somewhat verifiable via (patterns between) count of photons sent Vs detected |
| Apr2-12, 11:38 AM | #77 |
| Apr2-12, 11:54 AM | #78 |
| Apr2-12, 08:42 PM | #79 |
It is understood that Malus's Law and QM were derived independently.
I = Im cos2 theta cos2 30o = .75 cos2 60o = .25 cos2 120o= .25 cos2 45o = .5 And when polarizing plates are parallel , 0o, 180o cos2 = 1 For QM : 1/2Pi integral cos2(theta) d(theta) = same as above (1/2Pi) How then can the mechanism in Malus's Law be discounted in having an effect (not cause ) in the Bells Inequalities violation counts ? http://www.physicsforums.com/showthr...lus+law&page=4 |
| Apr2-12, 10:09 PM | #80 |
Your claim is, in part, that LR models can't reproduce the exact nonlinear correlation predicted by QM. I agree with this. Afaik, most everybody agrees with this. But you want to extend that mathematical fact to a statement about nature. Namely, that the incompatibility between LR and QM proves that nature is nonlocal. There do seem to be a number of physicists who believe this, but there are also a number who don't. I don't know the numbers, but, in my experience, no working physicist, teacher, professor, experimentalist, or theorist that I've talked to about this stuff believes that nonlocality has been proven vis the incompatibility between LR and QM -- with the possible exception of dBB advocates, who, it bears noting, have a sort of vested interest in interpreting Bell's theorem as proof positive that nature is nonlocal. The bottom line is that your n step proof(s) cannot possibly prove that nature is nonlocal, because the only thing that can possibly prove the empirical truth of such a statement would be the objective observance and recording of the ocurrence of ftl transmissions. Wrt which, afaik, there are none. I offered, in post #75, a certain way of looking at optical Bell tests to show that wrt a slightly less pedestrian (but not much less) and non-anthropomorphic conceptualization of what's happening in the quantum realm underlying instrumental behavior it's possible to construct a view of quantum entanglement (at least wrt certain simplified and idealized setups) that's compatible with the philosophical assumption of local determinism. Of course, this conceptualization doesn't prove that nature is local any more than your arguments prove that it isn't. It really is an open question, imho, as to whether nature is local or nonlocal. But modern physical science continues to assume (ie., proceed according to the working hypothesis) that nature, our universe, is evolving deterministically in accordance with the principle of locality, because these assumptions are the most reasonable given what's currently known. With this, I think I should fade back into the peanut gallery wrt this thread. As far as I'm concerned the OP's question has been answered. If he wants more info he can find it via PF, Google, Yahoo, arxiv.org, etc. searches. If you still want to discuss your n step proof(s) that nature is nonlocal, then I think the appropriate place to do that would be in the philosophy forum. |
| Apr2-12, 10:23 PM | #81 |
I suppose you're referring to some presumed underlying dynamics that result in the observations referred to collectively as supporting the Malus Law function. I would also suppose that virtually all optics texts have something to say about the mechanism underlying observations of Malus Law. |
| Apr2-12, 10:42 PM | #82 |
Thanks Thomas. My question has been answered namely - laws of probabilities are additive and hence linear. Bells proof, proving existence of quantum entanglement, seems valid to me within the scope of this question. If one has to go beyond that then it requires much more research and thinking. I will go through your posts in detail later this week.
the hypothesis that I had in mind was that at various angles it would not be linear however I realized that in LHV the photons would not even know the angle between the polarizers. The hypothesis that I had in mind however fits with QM |
| Apr2-12, 11:07 PM | #83 |
But don't waste any time on my posts. I'm as fascinated and confused about this stuff as anyone. A recommended path of inquiry would be to go back to Bell 1964 and work your way forward from there. When you have questions about a mathematical meaning or a conceptual line of reasoning, then present them at PF. |
| Apr3-12, 03:26 AM | #84 |
To be clearer I'll give an example (however deeper discussion would need a new thread): in Weihs' experiment, many pairs were actually detected but rejected for analysis by means of a very small time window, while reanalysis by De Raedt et al yielded a very different result with a larger time window; this was all matched with a partly ad hoc local simulation model. |
| Apr5-12, 07:48 AM | #85 |
a thought ..... 50% of all photons pass through a polarizer at all angles ..... - are the 50% different from the 50% that don't pass through (just like the initial conditions of a coin toss which shows heads is different from a coin toss which shows tails)? - are photon spins are partially malleable, by a polarizer, within limits? - do the members of the 50% pass-through group keep changing with the polarizer angle? |
| New Reply |
| Thread Tools | |
Similar Threads for: understanding bell's theorem: why hidden variables imply a linear relationship?
| Hidden variables | Advanced Physics Homework | 0 | ||
| Hidden variables, Bell's theorem, etc | Quantum Physics | 5 | ||
| Hidden Variables | Quantum Physics | 9 | ||
| relationship between Linear and Rotational Variables | General Physics | 6 | ||
| QM hidden variables | Quantum Physics | 46 | ||
