Population Problem: Solve for When 51003 in Brampton
  • Thread starter Thread starter fomenkoa
    population
The discussion revolves around a population growth problem in calculus, specifically using the exponential growth formula P=P(original)e^kt. The original poster is trying to determine when the population of Brampton was 51003, given its growth over a 20-year span from that point to a population of 149030.
  • Participants explore different ways to set the time variable t, with suggestions to let t=0 correspond to the year 2000. There are discussions about how to derive the growth factor k and the implications of choosing different reference points for time. Some participants express confusion about integrating the 20-year period with the known population figures.
The conversation is ongoing, with various approaches being discussed. Some participants have proposed equations to find k and t*, while others are questioning the assumptions made regarding the time frame and the application of the population model. There is no explicit consensus on the method to be used, but several productive lines of reasoning are being explored.
Participants note the challenge of working with a 20-year period without specific dates and the implications of choosing different starting points for the time variable. There is an acknowledgment that the growth rate k should remain consistent regardless of the reference point chosen.
fomenkoa
Hi everyone
I'm having trouble with this problem, while preparing for my calculus test this Monday...could anyone help me figure out the solution...I know that I must use the formula P=P(original)e^kt where t is time, and k is the growth factor but I'm not sure how to work with the years:
Over a span of 20 years the population of Bramptom increased from 51003 to 149030. The population of Brampton in 2000 was 310792.
a)Assuming the population model applies to the entire relevant domain when was the population 51003?
Thanks a lot
Anton
It is simplest to let t=0 correspond to year 2000.
Hence, you may write:
[tex]P(t)=(310792)e^{kt}[/tex]
You have two unknowns here:
k
and t*, the time measured from t=0 when the population is 51003 (the other time is, of course, t*+20)
t* will be negative.
I still can't figure it out...all these years and variables are confusing
Is
49030 = 51003e^k(t+20) right as a first formula?
I'm really confused :-p
Is 1966 the answer?
Well, yeah but I can't figure out the method of solution...which two fomulas to create to determine k
Now, can we agree on one thing:
It does not really matter which instant we choose to assign the time-value "0",
but once we've made our choice, we should proceed in a CONSISTENT manner?
Yeah...but how can one integrate a random period of 20 years with no dates given and the year 2000...that's what gets me confused...we don't know the dates when the 20-year period takes place
The way I did it is by first setting t = 0 at the time where the population was 51003. Then, P(20) = 149030 = 51003 exp(20k) and this allowed me to find the value of k.
Then, by setting t = 0 at birth of Christ, I found P(0) by setting P(2000) = 310792 and solving for P(0), which gave the dubious "something^(-42)" .. Then, I just isolated ? in P(?) = 51003 = P(0) exp(?t).
Does this make sense to you? The key is that k has the same value no matter where you set t = 0 because the growing rate of the population is the same at any moment of its history.
It is precisely for this reason it is easiest to choose our known year as t=0.
As I've shown, this means as a function of time, we have:
[tex]P(t)=310792e^{kt}[/tex]
Note that P(0)=310792, which is the population in year "2000", which we chose to correspond to t=0.
Your two equations are now:
P(t*)=51003
P(t*+20)=149030
These equations can now be solved for t* and k.
