Do we really need a cutoff in QFT
  • Context: Graduate
  • Thread starter Thread starter geoduck
    Qft
The discussion centers on the necessity and implications of a cutoff in quantum field theory (QFT), particularly regarding its value and the transition from bare to physical parameters. Participants explore the role of cutoffs in calculations, the relationship between cutoffs and mass scales, and the effects of renormalization group transformations.
  • Some participants question whether the cutoff in QFT needs to be set to infinity, suggesting that once bare parameters are replaced with physical parameters, the cutoff may not affect physical quantities.
  • Others argue that in practice, cutoffs are set to sufficiently high values for results to converge, rather than being taken to infinity.
  • There is a discussion about the relationship between cutoffs and mass scales, with some asserting that a mass scale is used to facilitate calculations when a finite cutoff is employed.
  • One participant describes a method of integrating out fields with momentum greater than the cutoff, suggesting this can lead to a new action with different coefficients, while questioning the necessity of introducing a mass scale in this context.
  • Another participant introduces Wilson's renormalization group flow, explaining how changing the cutoff affects coupling constants and the flow in phase space, and discusses the implications of having an ultraviolet fixed point versus an infrared fixed point.
  • Concerns are raised about the implications of taking the cutoff to infinity, particularly regarding the behavior of wavefunction renormalization and the invariance of physics under renormalization group transformations.
Participants express differing views on the necessity of setting the cutoff to infinity and the implications of doing so. There is no consensus on whether the cutoff is essential or how it interacts with mass scales and renormalization processes.
Participants note that the discussion involves complex mathematical and theoretical considerations, including the dependence on specific assumptions about the behavior of theories under renormalization and the nature of fixed points in the renormalization group flow.
geoduck
Does the cutoff really have to go to infinity in QFT?
It seems that once we replace bare parameters by experimental (i.e. physical) parameters, the cutoff vanishes from the expressions for physical quantities, so it didn't matter what the value of the cutoff was, whether it's 0, 10000000000, or infinity. So do you really have to take the step of setting the cutoff to infinity after replacing bare parameters with physical parameters? It doesn't do anything, right, since the final expression doesn't involve the cutoff at all, so the cutoff can be any value and that wouldn't change the value of physical quantities.
Also, say the cutoff is 10000000000, and you conduct an experiment at the same energy (10000000000). Does the bare parameter then equal the experimental parameter?
In practice, nobody actually sets cutoff to infinity. They set it to a value that's high enough for results to converge.
Do you work with a cutoff, or a mass scale μ?
I thought usually the cutoff was traded for a mass scale μ, and this occurs when you replace bare parameters with physical parameters. You can vary the mass scale μ to get your results to converge, but the cutoff should vanish once μ appears in your equations.
Mass scale, of course. But that's basically what you use to get away with using a finite cutoff. Is there another way of doing that? I wasn't aware of one.
The mass scale remains even when the cutoff goes to infinity.
If you can integrate out all fields with momentum greater than the cutoff in the path integral for the action, then that can be viewed as a renormalization group transformation that produces a new action with new coefficients and even new, unrenormalizeable interactions. Using this new action, you only need to integrate to a finite cutoff. I'm not sure if a mass scale is every introduced in this scheme, but rather you rely on the finite cutoff, and figure out how the coefficients change with cutoff.
Since the new action is numerically equal to the old action, the physics remains the same, only now you can't calculate correlators of momentum greater than the cutoff since you coarse-grained everything. But for low energy calculations this is not a problem.
Taking the cutoff to infinity implies the distance scale goes to zero which implies the correlation length goes to infinity which implies all theories where the cutoff goes to infinity are based on fixed/critical points. I'm not exactly sure what the point is of interpreting renormalization this way. If you don't force the cutoff to infinity, then your theory doesn't have to be based on a fixed point, but in any case this doesn't help you at all with the calculations.
If you have an integral where you can practically push the cutoff to infinity, you can renormalize at infinity and not have to worry about scale, no? Maybe this isn't true for a general case, but for quark DSE that would definitely work if I could actually integrate out to infinity and deal with infinite renormalization terms.
So wait, what you effectively do is numerically integrate up to cutoff and analytically past cutoff? Presumably under assumptions of perturbative QCD or some other simplification that only works at high energies?
I've had time to do a little more reading, and evidently it's all understandable from Wilson's renormalization group flow.
The idea is that you have a cutoff Lambda and some coupling constants g_i. If you change Lambda, the renormalization group dictates you must change the coupling constants g_i to give you the same physics, so that g_i=g_i(Lambda). Now imagine a multi-dimensional phase space, with the g_i's as the axes. You begin your system with some cutoff Lambda_init and coupling constants g_i_init. If you alter the parameter Lambda_init to Lambda', your point g_i_init in phase space flows to a new point g'_i(Lambda'). Now there are two ways you change Lambda_init: you can go up or down. Going up is what you're doing when you take the cutoff to infinity. You go down by integrating out higher momentum fields. Once you integrate out higher momentum fields, in all your loop integrals you don't need to integrate up to that high of a momentum since you integrated it directly out of the path integral in the beginning to give you new effective Lagrangian.
The mass scale μ corresponds to integrating out momenta from Lambda to Lambda/b, where b>1:
μ=Lambda/b
What you do in renormalization is that you set μ constant and take the cutoff Lambda to infinity. That is, your renormalized couplings don't change even though you take the cutoff to infinity. Why is this so?
It's because what you do is take Lambda to infinity, but then you go back down by increasing b in such a way that:
μ=Lambda/b is constant.
So when you increase Lambda, you're moving up the trajectory in phase space, but after you do that, you go back down by integrating out more modes that are less than Lambda but greater than Lambda/b.
So the cutoff can have any arbitrarily high value which will move you up the RG trajectory, but your parameters won't change because you just move back down by integrating out more modes.
All this is only possible if your theory is based on an ultraviolet fixed point so that if your cutoff is exactly equal to infinity, you arrive at the fixed point in the opposite direction of integrating out momenta. If the theory is based on an IR fixed point then as you take your cutoff to infinity you actually move towards the same direction as integrating out momentum so you can't undo taking the cutoff to infinity.
Note also that when μ=cutoff, your wavefunction renormalization Z_phi goes to 1 as all your two-point loop integrals go to zero. This is good because it is demanded by invariance of physics under renormalization group transformation. μ=cutoff corresponds to b=1, or just the bare theory. Because in the fundamental (bare) theory, there is no such thing as Z_phi.
Anyways, I might have some things wrong, but this is how I understand it so far from reading some beginning books and papers on the renormalization group (from the viewpoint of phase transitions and critical phenomena rather than particle physics though). I have a presentation to give on this in 3 weeks, so I'll be studying this further.
  • · Replies 89 ·
  • · Replies 38 ·
  • · Replies 18 ·
  • · Replies 31 ·
  • · Replies 473 ·
34K
