How do I calculate the bending moment in a beam for my ramp design?
This discussion focuses on calculating the bending moment for a ramp designed using a 50.8 mm square aluminum tube with 3.25 mm walls, measuring 2 meters in length. The ramp must support a point force of 200 kg, equivalent to 1962 N, applied at the midpoint. The Young's modulus for aluminum is established as 69 GPa. The bending moment can be calculated using the formula: (length of beam * force) / (Young's modulus * cross-sectional area), with the cross-sectional area determined to be 319.6375 mm².
  • Understanding of basic mechanics and beam theory
  • Familiarity with Young's modulus and material properties
  • Knowledge of cross-sectional area calculations
  • Ability to perform unit conversions (mm² to m²)
  • Research the calculation of bending moments in beams using point loads
  • Learn about the properties of aluminum, including Young's modulus
  • Explore beam deflection calculations and their significance
  • Utilize online beam calculators for practical applications
Students in engineering or physics, mechanical designers, and anyone involved in structural analysis or ramp design will benefit from this discussion.
sockless
So for school I'm designing a ramp. The problem is that I need to calculate various things in it, none of which I've ever been taught, since I'm pretty sure it's all uni level. I've asked multiple teachers, including my physics teacher and my technology teacher, and they haven't been any help.
Basically, my ramp is a 50.8 mm square aluminium tube with 3.25mm walls, which is 2m long. I want it to be able to hold at least 200kg, which I guess can be modeled as a point force in the middle (i.e. 1m). However, I don't have a clue how to calculate the bending moment, so that I can calculate the strength of the beam (via it's section modulus, which I have figured out). The ramp is supported at both ends and can be modeled as being horizontal. I've looked on the internet, but nothing makes any real sense.
I don't want the solution as much as I want an explanation on how to calculate the bending moment.
let's calculate beam deflection first. as if it were horizontal.
you have to look up the young's modulous for aluminum. Wikipedia says 69 gigapascals.
okay here's the most basic equation:
(length of beam * force) / (young's modulus * cross section area)
result is in meters.
length of beam = 2m
force= 200kgs*9.81= 1962N
young's mod=69Gpa (1pa =1 N/m2)
cross section= 50.82-(50.8-3.25)2= 319.6375mm2 =0.0003196375 m2
plug and chug:
2 meters * 1962 Newtons / 69x109Newtons/meter2 * 0.0003196375 m2
=0.00000017791894 meters
That probably didn't help. sorry.
Well Huntoon wasn't much help, fortunately its a pretty easy calculation. Everything you need can be found here:
http://www.efunda.com/formulae/solid_mechanics/beams/casestudy_display.cfm?case=simple_centerload
The specific equation you're looking for is:
Note that beam calculator I linked to will also calculate the max stress.
  • · Replies 30 ·
10K
