Calculating Specific Heat Capacity of Nickel with Coffee Cup Calorimeter Method
  • Thread starter Thread starter courtrigrad
    Chemistry
The discussion revolves around calculating the specific heat capacity of nickel using a coffee cup calorimeter method. The scenario involves a nickel sample being heated and then placed in water, with the goal of understanding the heat exchange between the two substances.
  • Participants discuss the principles of thermal equilibrium and the heat exchange equation, questioning the signs used in the equations and the definitions of specific heat. There are attempts to clarify the relationship between the specific heat of nickel and water, as well as the correct application of temperature changes.
The discussion is ongoing, with participants exploring different interpretations of the equations and the concepts involved. Some guidance has been offered regarding the signs in the heat exchange equation and the use of temperature changes, but no consensus has been reached on the specific calculations.
Participants are working under the assumption that no heat is lost to the surroundings and that the system reaches thermal equilibrium. There is also a focus on the specific heat values and the correct application of the formula involving mass and temperature change.
courtrigrad
A 28.2 g sample of nickel is heated to 99.8 C and placed in a coffee cup calorimeter containing 150.0 g water at 23.5 C. As the metal cools, the final temperature of metal and water is 25 C. Calculate the specific heat capacity of nickel, assuming that no heat escapes to the surroundings or is transferred to the calorimeter.
I know that
energy relased = s * m * ∆T
So would ∆T = 25 - 23.5?
Also would the mass = 28.2 g
Finally how would you calculate the specific heat capacity of only nickel?
Thanks a lot
There will be a thermo equilibrium so
[tex]-Q_{nickel} = Q_{water}[/tex]
[tex]-m_{nickel}c_{nickel} (T_{final} - T_{nickel}) = m_{water}c_{water}(T_{final} - T_{water})[/tex]
oh ok
so the specific heat of water = specific heat of nickel?
No, you need to work out the equation to get it.
wait what is c? aren't you supposed to use s * m * ∆T??
C is specific heat. I apologize for my notation, that's how i remember it from the course.
no problem. was just wondering how you received the thermal equilibrium? Like putting a - sign in front of Q(nickel)
As i remember the - sign in thermodynamics means losing heat, and the + sign remember gaining heat, so as you can see there will be an exchange of heat energy between the nickel and the water, til they hit an equilibrium.
A more "savvy" way, i remember using was looking at the final temperature and at the initial temperature, as you can see the final temperature < initial temperature therefore the incrementum will be negative for the nickel.
hmmm got 0.93 when answer is 0.45. For ∆T of nickel and water, do you use the same final temperature 25.0 C?
I got 0.445 j/g C, yes you do that's the whole point of thermo equilibrium.
yes i got that. thanks a lot for helping me
