How do I evaluate this properly? Trig
  • Thread starter Thread starter aisha
    Trig
The discussion revolves around evaluating the trigonometric expression cos(-π/12), with participants exploring the conversion of the angle to degrees and the application of trigonometric identities.
  • Mathematical reasoning, Problem interpretation
  • Participants discuss using the sum and difference formula for cosine and express confusion regarding the correct application of the formula. There is an exploration of angle conversion and the impact of calculator use on the results.
Some participants have offered corrections to the formula used, while others are attempting to verify their calculations. There is ongoing dialogue about the accuracy of the results and the methods applied, indicating a productive exchange of ideas.
Participants are working under the constraints of evaluating a trigonometric function and are questioning their calculations and the formulas used. There is mention of potential errors in calculator input and the need for careful step-by-step evaluation.
aisha
I have the question evaluate the following : cos(-pi/12)
I rewrote this to be -15 degrees = 345 degrees.
I think I am supposed to use the sum and difference formula or special triangle, so I wrote
cos(30degrees-45degrees)= cos 30 cos 45 - sin 30 sin 45
my answer turned out to be 0.5124 but it says the correct answer is 0.9659 what did I do wrong?
U applied the 'cosine' formula incorrectly.It should read
cos(30degrees-45degrees)= cos 30 cos 45 +sin 30 sin 45
I think it gives you the right answer.
Ok I changed the sign but now my answer is 1.219 it is still wrong
You added wrong, aisha
yes ur right thanks i didnt do it separately I just input the whole thing into the calculator thanks :smile:
