Static Equilibrium Problem Dealing with Torque
by PeachBanana
Tags: dealing, equilibrium, static, torque
PeachBanana
PeachBanana is offline
#1
Mar30-12, 08:41 PM
P: 191
The figure shows a model of a crane that may be mounted on a truck. A rigid uniform horizontal bar of mass = 90.00 kg and length = 5.200 m is supported by two vertical massless strings. String A is attached at a distance = 1.600 m from the left end of the bar and is connected to the top plate. String B is attached to the left end of the bar and is connected to the floor. An object of mass = 3000 kg is supported by the crane at a distance = 5.000 kg from the left end of the bar.
Throughout this problem, positive torque is counterclockwise and use 9.807 m/s^2 for the magnitude of the acceleration due to gravity.
Find the tension in string A.
2. Relevant equations
This problem lets you use hints and it suggested I use the following equation with having the Tension in String "B" as the origin.
3. The attempt at a solution
Tension A(1.6000m) - (90.00 kg)(9.807 m/s^2) 1/2(5.200 m) - (3000 kg)(9.807 m/s^2)(5.000 m) = 0
I don't understand the "1/2" part in front of the length mass one. Is that because of where it is placed or its moment of inertia?
Phys.Org News Partner Science news on Phys.org
Internet co-creator Cerf debunks 'myth' that US runs it
Astronomical forensics uncover planetary disks in Hubble archive
Solar-powered two-seat Sunseeker airplane has progress report
PhanthomJay
PhanthomJay is offline
#2
Mar30-12, 09:39 PM
Sci Advisor
HW Helper
PF Gold
PhanthomJay's Avatar
P: 5,966
If the weight of the 90 kg beam is uniformly distributed over its length, where does its resultant load act?
PeachBanana
#3
Mar30-12, 10:27 PM
P: 191
I'm sorry, I'm not sure what you mean by resultant load.
PhanthomJay
#4
Mar31-12, 09:57 AM
Sci Advisor
HW Helper
PF Gold
P: 5,966
Quote Quote by PeachBanana View Post
If a uniform beam that is 2 m long has a mass of 0.5 kg/m, its total mass is 1 kg and it's resultant or total weight is 9.8 N. It can be represented as a single force of 9.8 N acting at its center of gravity.
Register to reply
Related Discussions
Problem dealing with Equilibrium & Torque Introductory Physics Homework 4
Length of bar needed to lift a crate(Torque, static equilibrium problem) Introductory Physics Homework 1
static equilibrium and torque problem Introductory Physics Homework 5
Torque/Static Equilibrium/Forces problem.... Introductory Physics Homework 4
Static Equilibrium/Torque/Force problem General Physics 0
