| New Reply |
Scholarpedia article on Bell's Theorem |
Share Thread | Thread Tools |
| Apr25-12, 08:31 PM | #443 |
Scholarpedia article on Bell's TheoremYes, it does. [itex]P(b_1 |B_3 , b_2 ) \neq P (b_1 |B_3 )[/itex] implies nonlocality. But you have to read and understand and remember the words -- in particular that B_3 denotes a complete description of the physical state of a certain spacetime region, that b_2 has to live in a certain spacetime region (and can't be just any old extra thing you want to throw in), and that the P's are the fundamental dynamical probabilities assigned by some physical theory (as opposed to the kinds of probabilities that are based on ignorance of various things, etc.). If you actually hold all this in mind, it's trivial to see why all your examples, with the balls in the urns and whatnot, don't show what you think they show. Seriously, you have to actually slow down and read and process Bell's formulation. Let it marinade. (Sorry, I'm watching American Idol in the background.) Understand and appreciate what he's doing. Bell is not a dummy and he didn't formulate "locality" in a way that would diagnose, as nonlocal, trivial cases of correlation-without-causation like the ones you bring up. If you think it's so easy to refute -- if you think Bell is a dummy -- it only shows that you haven't taken the time to understand and appreciate what he accomplished. Here, I'll put it as a challenge. State clearly, for your balls and urns or whatever example you want, what b_1, b_2, and B_3 are. Convince yourself and me that these satisfy all the conditions Bell laid down. (So, for example, oh, i dunno, B_3 better not turn out to be something like "what somebody who doesn't know the color of the first ball pulled knows about the state of the urn", and b_2 better not turn out to be in the past of b_1 rather than at spacelike separation and also outside the future light cone of region 3.) Then see if you still think there is some counter-example to Bell's formulation here. |
| Apr25-12, 09:15 PM | #444 |
(2) It makes no sense for a *deterministic local hidden variable theory* to allow for the possibility of an irreducable stochastic theory, which is completely contrary to the concept of a *deterministic local hidden variable theory*. THEREFORE, if you *assume a deterministic local hidden variable theory*, your statement implies that Bell's locality concept would cease to work in the narrow confines of your assumption. Maybe you misspoke in the article but this is clearly the meaning conveyed by the text. |
| Apr25-12, 09:49 PM | #445 |
So here is my definition of "probability": a probability is a theoretical construct, which is assigned to represent a state of knowledge, or calculated from other probabilities according to the rules of probability theory. A frequency is a property of the real world, which is measured or estimated.And my definition of "cause": To say "C" (a cause) causes "E" (an effect) means that whenever C occurs, then E follows. Therefore we can not say "C" causes "E" if the two events are simultaneous. Similarly if "E" occurs before "C", then "C" can not be the cause of "E"I'll wait for your definitions. |
| Apr25-12, 10:56 PM | #446 |
While waiting for your definitions I thought I should also point out the following mathematical contradictions. NOTE, the following is simply a mathematics exercise, no physics whatever, but it clearly shows the problem Bell proponents are still unable to see:
Consider the CHSH inequality: |E(a)E(b) - E(a)E(c)| + |E(d)E(b) + E(d)E(c)| ≤ 2, where E(a), E(b), E(c), E(d) ∈ [−1,1] This inequality is violated IFF (1) |E(a)E(b) - E(a)E(c)| + |E(d)E(b) + E(d)E(c)| > 2 We are interested to understand the mathematical properties of the 4 terms E(a), E(b), E(c), E(d) when this violation happens From (1) we have via factorization (2) |E(a)||E(b) - E(c)| + |E(d)||E(b) + E(c)| > 2 However, since E(a), E(b), E(c), E(d) ∈ [−1,1], it follows that |E(b) - E(c)| ≤ 2 and |E(b) + E(c)| ≤ 2 Let us consider the different possible extremes of the values for E(b) and E(c). If E(b) = E(c) then |E(a)||E(b) - E(c)| = 0 and |E(d)||E(b) + E(c)| must be greater than 2 for equation (1) to hold. But we know that |E(b) + E(c)| ≤ 2 which means |E(d)| must be greater than 2 which is impossible given that E(d) ∈ [−1,1]. If E(b) = -E(c) then |E(a)||E(b) + E(c)| = 0 and |E(a)||E(b) - E(c)| must be greater than 2 for equation (1) to hold. But we know that |E(b) - E(c)| ≤ 2 which means |E(a)| must be greater than 2 which is impossible given that E(a) ∈ [−1,1]. Therefore (1) is mathematically impossible. It is not possible mathematically to violate the CHSH inequality even before we start talking about any physics and what the terms might mean in any physical situation. This is the simple fact that Bell proponents are blind to. I challenge anyone to find values for E(a), E(b), E(c), E(d) ∈ [−1,1] that violate the above inequality from any source whatsover using any means whatsoever. You can even assume that E(a) are averages over many runs or whatever you like. |
| Apr26-12, 04:39 AM | #447 |
(Your def'n of "probability" is inapppropriate in this context, as I've explained. And your definition of "cause" smuggles in the presupposition of determinism, which is a problem for the reasons I've explained.) Now I give up. |
| Apr26-12, 09:12 AM | #448 |
After your article "Against Realism" in explained that many people arguing about Bell do not know what "realism" means, I would have thought you would understand the importance of clear definitions of terms. Once, you provide your definitions it would become evident that you do not know what you are talking about. All your claims about having explained things clearly in your articles, when you don't even have consistent definitions of terms will become evident. I'm still waiting for your definitions for "probabilities" and "cause". |
| Apr26-12, 09:41 AM | #449 |
| Apr26-12, 09:51 AM | #450 |
Getting to the truth is not always fun if you are on the wrong side. This is not an entertainment exercise. |
| Apr26-12, 10:47 AM | #451 |
| Apr26-12, 11:10 AM | #452 |
| Apr26-12, 11:34 AM | #453 |
| Apr26-12, 03:19 PM | #454 |
Since you like my questions so much, I thought I should add another. You say:
How did you make sure in your experiment that X is a complete specification? In other words: How have experimenters performing Aspect type experiments made sure that X is a complete specification? You admit in your article that [itex]P(b_1 |B_3 , b_2 ) = P (b_1 |B_3 )[/itex] ONLY implies local causality if B_3 is a complete specification and b_2 adds nothing. Therefore unless you can make sure in an EXPERIMENT (X) that everything relevant for the outcome is specified, you can not reject local-causality on the basis of such a violation. Put simply, "it is impossible to screen off a variable with another variable you know nothing about". Still waiting for your definition for "probability" and "cause" after which we will examine if your idea of "complete specification" is consistent with the definitions. |
| Apr26-12, 03:44 PM | #455 |
Highly enjoyable post ttn, and I want to respond to it with a full answer, but am currently snowed under. Will do so tomorrow.
| Apr28-12, 01:41 AM | #456 |
Recognitions:
It provoked me to buy the second edition of "Speakable and Unspeakable", just for the "Nouvelle Cuisine" essay. This was money well-spent.
| New Reply |
| Thread Tools | |
Similar Threads for: Scholarpedia article on Bell's Theorem
| Bell's Theorem | Advanced Physics Homework | 2 | ||
| Bell Theorem | Quantum Physics | 115 | ||
| Why is the Wikipedia article about Bell's spaceship "paradox" disputed at all? | Special & General Relativity | 109 | ||
| Original Bell article with the proof of his inequality Is necessary. | Quantum Physics | 2 | ||
| Bell's theorem | General Physics | 27 | ||
