Multivariable Vector: Gradient @ particular speed - Find Rate
The discussion focuses on calculating the rate of change of fluid concentration, represented by the function F(x,y,z) = 2x^2 + 4y^4 + 2*x^2*z^2, at the point (-1,1,1). The gradient of the function at this point is determined to be Grad(F) = <-8,16,4>. To find the concentration change while moving in the direction of the gradient at a speed of 8, participants confirm that the rate of change can be calculated using the formula \(\frac{dF}{dt} = \nabla F \cdot \frac{d\mathbf{x}}{dt}\), where \(\frac{d\mathbf{x}}{dt}\) is the unit vector of the gradient scaled by the speed.
  • Understanding of multivariable calculus concepts, specifically gradients.
  • Familiarity with vector operations, including dot products.
  • Knowledge of fluid dynamics and concentration functions.
  • Ability to compute unit vectors and their applications in directional movement.
  • Study the derivation and applications of gradients in multivariable calculus.
  • Learn about the physical interpretation of gradients in fluid dynamics.
  • Explore vector calculus operations, particularly dot products and unit vectors.
  • Investigate the implications of speed on concentration changes in fluid systems.
Students and professionals in mathematics, physics, and engineering fields, particularly those focusing on fluid dynamics and multivariable calculus applications.
MJSemper
Given: Concentration of Fluid = F(x,y,z) = 2x^2 + 4y^4 + 2*x^2*z^2 at point (-1,1,1)
Found Grad(F(x,y,z)) = <-8,16,4>
----If you start to move in the direction of Grad(F) at a speed of 8, how fast is the concentration changing?
Already found the gradient ... = < 4x+4xz^2, 16y^3, 4*x^2*z >
...at point (-1,1,1) = < -8,16,4 >
I know that the gradient is the direction of greatest change, and its magnitude is the particular rate thereof. What I'm stuck at is how the "speed of 8" plays in there. Is it a scalar value to the magnitude of the gradient vector?
I know |grad(F)| = sqrt(336)
--do I take the Unit Vector of the gradient and multiply it by the scalar 8?
I guess you should calculate [tex]\frac{dF}{dt} = \nabla F \cdot \frac{d\mathbf{x}}{dt}[/tex]
  • · Replies 22 ·
