Development of Magentic force equation to include angle
The discussion focuses on adapting the magnetic field equation B = μonI to account for the angle (θ) between the coils and the cylindrical core of an electromagnet. The proposed formula for the number of coils (n) is n = k(sin(θ)*l)/(2(pi)r), where k is a constant, l is the length of the wire, and r is the radius of the cylinder. The revised magnetic field equation becomes B = k(μoI(sin(θ)*l))/(2(pi)r). The accuracy of this equation is questioned, particularly regarding the density of windings and its implications on the magnetic field strength.
  • Understanding of electromagnetism principles, specifically magnetic field equations.
  • Familiarity with trigonometric functions, particularly sine.
  • Knowledge of coil winding techniques and their impact on magnetic fields.
  • Basic grasp of physical constants such as μo (permeability of free space).
  • Research the impact of coil density on magnetic field strength in electromagnets.
  • Explore the derivation and applications of the Biot-Savart Law in electromagnetism.
  • Study the effects of varying angles in coil configurations on magnetic performance.
  • Investigate the role of physical constants in electromagnetic equations and their practical implications.
Physicists, electrical engineers, and students studying electromagnetism who are interested in optimizing electromagnet designs and understanding the effects of coil configurations on magnetic fields.
Da Apprentice
Hi All,
B = μonI
I am trying to adapt this formula to include a dependence upon the angle made by the coils relative to the cylindrical core of the electromagnet. For example it is known that the number of coils (n) that can be formed around a cylinder should be dependent upon the length of the given wire (l), the angle made between the wire and the cylinder (θ) and the circumference of the cylinder (2(pi)r). Where the number of coils should be proportional to length, inversely proportional to the circumference and proportional to the sine of the angle)
Therefore the equation used to determine the number of coils should be;
Where k is some constant, With the assumption made that the wire is wound as tightly to the cylinder as possible (there isn't a gap between the wire and the cylinder).
Therefore the main equation can be written as;
Is this a correct equation for determining the force based upon the angle made by the coils relative to the cylindrical core or is there another variable which I am overlooking?
Thanks,
Z.C
If I understand your setup correctly, you get a low density of windings (if sin(theta) is not close to 1). In that case, the formula B=my_0 n I might be a bad approximation.
Force?
  • · Replies 16 ·
10K
